0 Members and 1 Guest are viewing this topic. Read 3203 times.
If I want to run a true biwire setup with the 4BSST-2 with two sets of spade terminated wires at the amp end is there any way to open up(unscrew all the way) the binding post to accommodate this? Or will I have to bite the bullet and order one pair terminated in spades and the other in bananas to accomplish this? Thanks guys!
Thanks for the pic, James. Those are locking bananas, true?
James,What binding posts do you use on the squared amps that accept bananas and spades?You can PM me if you need to.Thanks,Bill
Question for James.If i had 2 sets of cables with banana ends and wanted to Bi-wire.Could I put one set of bananas in the holes were the spades are connected in your picture.Or would it be better to get a banana to spade adapter. If so any suggestions for such an adapter.
the hole is not really that large (that's what she said )
