$175 Class D amp--120 wpc
0 Members and 2 Guests are viewing this topic. Read 1219760 times.
jtwrace
    • TIPP YouTube Channel
Re: $175 Class D amp--120 wpc
« Reply #1420 on: 12 May 2010, 12:22 am »
Also know as Unibit...It works but is a crude way to drill a hole.  You really need to file after to get all the burrs off.
wushuliu
« Reply #1421 on: 12 May 2010, 12:38 am »
oh, excellent. I think I found a unibit that will work perfect. I'm pretty sure I have a file in my tool box, so should be good there. thanks much!
jtwrace
« Reply #1422 on: 12 May 2010, 12:40 am »
 :thumb:   Measure twice or as many times as it takes to get it right the first time.  Masking tape or painters tape works best.  Tape the surface to be drilled then use a fine tip Sharpie to mark before drilling.  Of course using a center punch then drill a small pilot hole ~1/8" then use the Unibit.  This will keep the Unibit from "walking".
roymail
  • Roy in TX
« Reply #1423 on: 12 May 2010, 12:41 am »
I put some masking tape where I want to drill, mark it clearly, then use several small bits to work up to the hole size.  Making a pilot hole is a must, and go slow.  Good bits help a lot, worn bits don't work well.
But, that said, it's not hard to do... get 'er done!
Mariusz
« Reply #1424 on: 12 May 2010, 12:42 am »
Yeah, small half-round file might be needed.
roymail
  • Roy in TX
« Reply #1425 on: 12 May 2010, 12:42 am »
Looks like Jason and I had the same things to say while we were typing at the same time.  :thumb:
This is just me, but I'd stick with regular drill bits to do this simple job.  Don't really need a "step-up bit."
jtwrace
« Reply #1426 on: 12 May 2010, 12:43 am »
Great minds think a like.   :lol:
wushuliu
« Reply #1427 on: 12 May 2010, 12:47 am »
Terrific! Thanks guys. I'll probably take pics and write it up, of course... :rock:
inept
« Reply #1428 on: 12 May 2010, 01:32 am »
I'll second the step drill bit.
I've used regular drill bits, small one for pilot hole and 1/2" I think for the final hole for binding posts, and a stepped drill bit.
The stepped bit was much faster and cleaner,...just be sure to mark the bit where you want to stop, i wrap a piece of tape around the step just above the size I need.
avionic
« Reply #1429 on: 12 May 2010, 05:47 am »
The par metal cases are very easy to drill,cut etc. I used a punch and regular drill bits. Smaller for pilot holes then stepped up to size needed. As already mentioned masking tape and draw everything out with a pencil or something else eraseable. For the IEC outlet you can use a skill saw with a metal cutting blade. Works like a champ. When your done cutting and or drilling you can clean up the holes with a file or sand paper as the metal is fairly soft.
wushuliu
« Reply #1430 on: 12 May 2010, 03:49 pm »
Well the new amp board is up and running and everything seems okay :D. I'll be ordering the Par-metal in  a couple days...
Nick77
« Reply #1431 on: 12 May 2010, 05:11 pm »
Great news! Glad your PS survived the storm. :green:
cynan
« Reply #1432 on: 12 May 2010, 08:11 pm »
Earlier in this thread someone was asking for opinions of going with one of the linear PSU boards at connexelectronics.com over the one offered at classDaudio.com. I don't think anyone addressed this. Unfortunitely, I can find very little info about them on the website. Does anyone have an opinion about either of these modules with the SDS-254 or SDS-258? Would the combined 60,000uf capacitance of these be any sort of an upgrade?
http://connexelectronic.com/product_info.php/products_id/69?osCsid=3prbrltmu15kfebq69if854uf2
http://connexelectronic.com/product_info.php/cPath/25_45/products_id/87?osCsid=3prbrltmu15kfebq69if854uf2
wushuliu, what size of par-metal case would you be considering? 12x12x4 or 12x16x4?
roymail
  • Roy in TX
« Reply #1433 on: 12 May 2010, 08:14 pm »
Hi guys,
OK, there has been some confusion about the input impedance of the CDA and SDS amp boards.  I want to thank Deward for his technical help and Tom for giving me a more complete explanation as to why some boards measured differently than others.  Here is the email I received earlier today.  I'm posting it with Tom's permission.
Hi Roy,
I’m sure there is some confusion on the impedance of the CDA series amps. They have gone through changes since out first design. Our first amps worked well with most preamps and input devices, but they did have very low input impedance, and some with tube preamps had problems. Since that time, we have made several changes to try to make them more compatible and able to match up well to all available input devices. We have used up to 45K, but now we have settled on 7.5K input impedance for the CDA series. This seems to match up very well with all available audio equipment so far, and keeps the input noise down to a minimum. The SDS amps have an input impedance of 45K in balanced mode, and about 42K in single ended mode. This seems to work great with these amps and the balanced input stage. For some time now, we haven’t heard of any problems matching our amps to other input devices.
I hope this helps shed some light on this topic. Please let me know if I can be more help.
Tom
Nick77
« Reply #1434 on: 12 May 2010, 08:26 pm »
I dont have any advise on the supply in question but several of us have gone with just swapping out the stock Nichicons with Panasonic tsha series with positive results. It is not clear whether the increase in capasitance was the reason or the better caps. In both cases the increase was to 40,000uf and hasnt been confirmed if going higher is of any value or not.
cynan
« Reply #1435 on: 12 May 2010, 11:00 pm »
what happenned to the half dozen posts that were posted after this today?
jtwrace
wushuliu
« Reply #1437 on: 12 May 2010, 11:04 pm »
Split off this thread, for those feeling a little, er, Lost. No merging back. Whatever happened, happened.  :wink:
Mariusz
« Reply #1438 on: 12 May 2010, 11:40 pm »
jtwrace
some members feel the need to expend on the topic and more techical side of it, including modifications etc. Ones we start moving away from the original topic and essence of this thread it will become more & more confusing for new readers.
We are already covering more then few versions of this amp and I see that it might look a bit "loose" for someone who just started fallowing this topic.
It will be also easier to refer future questions to coresponding thread in appropriate circle.
Mariusz
mcgsxr
« Reply #1439 on: 13 May 2010, 12:50 pm »
I had been considering building one of these kits up as a sub amp, but the simplicity of the BASH 300 for $175 shipped to me in Canada won out in the end.
I will keep my eye on this thread though, as I may in time move away from my 96db efficient OB speakers, and look for affordable, good power - these appear to deliver that in spades!
