0 Members and 2 Guests are viewing this topic. Read 1219764 times.
So does that mean that single ended inputs are equally as good as balanced, or that balanced inputs are no better than single ended?
The CDA input impedance is quite low . . . typically 4000-5000 Ohms (depending on the built-in gain setting). Not all sources can drive that properly . . . so-called “passive pre-amps”, for example, cannot, producing interactions that can induce distortion and compromise frequency response. On the other hand if your source can handle the load it is not an issue.
Tom has assured me that the input impedance of their amps is 45k. I have the emails if anyone needs to see them. Just trying to help and limit any confusion.
So are these amps still going to be featured in Affordable Audio?
I'm sending a PM your way.Previously, Blair Lamphear (Niteshade Audio), stated that the CDA-254 worked great with a passive attenuator and raved about the amp's performance. I don't believe that Blair would say that and market his own version of the amp using the CDA-254 amp board if it had so many issues.
The latest from Tom is it should be in the June issue.steve
He's obviously a big fan of these amps and is just presenting options, especially to those of us who like to wake up to the smell of solder in the mornin'
Love it! Diy Rules!
Have to be careful though. I just fried my classd amp this weekend Not quite sure what happened, but we had just finished moving to a new place and I started getting audio stuff set up. Probably something got jostled (actually I'm sure it's related to my first modding attempts back when I got the board in November which was sloppy *and* unncessary). I was too eager to get things going, was very tired, and I knew i should have given everything a once over and made sure the enclosure was ok, etc.My new board should be arriving today... so be careful!
Should be. The sparks and smoke came from the amp . I'll find out tonight...
Did you get the same board?
Yes. I was tempted to get the Super, but my will is strong, like my kung fu!
Here's a question for enclosure folk: My amp is housed in a wood enclosure. It's alright, but I'd like to step up to one of the ParMetal enclosures on ebay.I have zero experience w/ metal enclosures. I live in an apartment and no access to major tools - just a basic drill. How do I go about making 3/8" and smaller holes for the rca/posts, etc? (rear panels are .06" thick aluminum). I've done searches all over, but surprisingly little info on these kinds of holes.if this question should go somewhere else, lmk...
Have you seen my gallery with my case? Take a look...it's right up your alley.
i know, but I am *way* broke. like post-move, post-flew to somebody's wedding far away, now post replaced dead amp broke...
