winter fun- a dvd frankenstien
0 Members and 1 Guest are viewing this topic. Read 2811 times.
rosconey
« on: 21 Jan 2004, 12:10 am »
going to try and modify a philips dvd727 :o
dont know a dam thing about how but-i did redo my michaura m55 crossovers and did the ones rick craig sent  with my kit :mrgreen:
my joints look good :smoke:  no cold welds :mrgreen:
i bought one of these a few weeks ago and it sounded great but made load up sounds i didnt like, so i bought a more expensive philips -i also like it.but it doesnt upsample :nono: the 727 does-24/192
work is going to be slow for a few months(dont matter i will finish a winters worth of work at the job tomorrow :mrgreen: )
so after work i'm going across the street and buy 2 of these-80$ each :bounce:   at target
will play with one and have the other for comparison :!:
first off how do i tell what size the caps are :?: is it printed on them or do i remove and test.
will also try a power cord upgrade- resistors-dampen chasis-rca conectors
any help welcome-
rosconey
« Reply #1 on: 22 Jan 2004, 12:52 pm »
well no go they are out of stock  :o
WerTicus
« Reply #2 on: 23 Jan 2004, 08:15 am »
i would say that modifying the philips dvd727 would definatly improve things... as a $100 player must have some cheap and nasty stuff inside!
rosconey
« Reply #3 on: 23 Jan 2004, 11:47 am »
going to comp usa today-heard they have some.
rosconey
« Reply #4 on: 23 Jan 2004, 08:55 pm »
got one :mrgreen:
Marbles
« Reply #5 on: 23 Jan 2004, 09:05 pm »
I liked the title to your thread....Edgar Winter, They Only Come out At Night is a GREAT LP, and one of the hits from it is the instrumental Frankenstein!
Did you title the thread on purpose to match that album?
rosconey
« Reply #6 on: 23 Jan 2004, 10:36 pm »
:mrgreen:
frankenstien is awsome :mrgreen:
rosconey
« Reply #7 on: 24 Jan 2004, 01:37 pm »
opened up the unit :o wow what a cheap piece of crap-
wish i had a camera-1 decent size cap on the power board, none of the others are any bigger than a pea :o
not so sure now about what to do, or even if i can do it.
but dam it sounds good
JohnR
« Reply #8 on: 25 Jan 2004, 01:02 am »
The diodes would probably be a good candidate to replace, and the power supply caps. If you search for Chris Fraser's page on DI/O mods, that will give you a good idea of the types of parts to look for :idea:
Please keep us update don how you go! :thumb:
rosconey
« Reply #9 on: 25 Jan 2004, 10:11 pm »
well the drive is a piece of crap-started skiping after about 6 cds today , the sound is awsome -anyway-
is it possable to add a different drive and use it as a dac?
this might be the best option is it can be done-the chip sounds very good :mrgreen: would make a great dac for 80$
