Help for KSai HT Project: Select PreProcessor and 5 Channel Amplification
0 Members and 1 Guest are viewing this topic. Read 1085 times.
saisunil
Hi,
I am an audio guy so I am reaching out to you all for HT help.
I'd appreicate recommendations (including if you have something appropriate to sell) for
1. Pre-Processor with latest HDMI Switching
2. 5 Channel amp
Most likely we'll be using GR-Research five AV speaker setup
with 2 subs (undecided)
Likely Projector: Sony - VPL-VW50 DILA
Budget ~$3500 for both - new/used/discounted/whatever ...
Sunil.
Audiophiliac
Depending on your needs and other equipment, you might research the just announced Denon S-5BD Bluray/AV receiver combo! It has 5 channels of amplification (preouts for surround back/front height), profile 2.0 BD player, HDMI 1.4 (3 inputs), USB digital iPod connection, network streaming, zone 2 function, etc.
The remote is a POS, and the unit is a bit pricey for what it is, but it might just fit your needs. :) Its a slick piece of gear for sure.
saisunil
Thanks for the input we'll probably for one of NADs
