Corrosion X spray
0 Members and 1 Guest are viewing this topic. Read 1508 times.
Corrosion X spray
« on: 8 Jan 2010, 03:08 pm »
Hi Lab Guys,
Do you already used Corrosion X spray on Amps or SACD player circuits??
What your impressions??
There is any other better product?? or Corrosion X is the best??
Thanks for yours opinions,
Gustavo
Speedskater
  • Kevin
Re: Corrosion X spray
« Reply #1 on: 8 Jan 2010, 06:33 pm »
a) It seems reasonable for use on switch and connector contacts.
b) Can't think of anything good that it would do on a printed circuit board.
c) But I can think of bad things that would happen if it got into a CD or DVD drive.
d) I wouldn't spray any oil based chemical inside a unit.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 8 Jan 2010, 06:34 pm »
I use Corrosion X at work and would NEVER use it on electrical items.  Use dielectric grease if you need to use something.
« Reply #3 on: 8 Jan 2010, 08:07 pm »
Hi, thanks for the infos.
I see Corrosion X on a store, the papers there say to spray in circuits too!!
I do not know it before, it is a oily product??
jtwrace
« Reply #4 on: 9 Jan 2010, 12:52 am »
Yes, it's a petroleum base to resist moisture.
http://www.corrosionx.com/marine.html
« Reply #5 on: 9 Jan 2010, 01:59 am »
Thanks for the confirmation Jtwrace.
So, I think better do not take risk to spray this spray in a HiFi circuit, as was suggested by this local magazine of my country:  http://clubedoaudio.com.br/loja/Produtos.aspx?IdCategoria=3
They are selling C-X it at low prices.
