Poll
Which outs are you using on your Transporter?
The HQ RCAs that Dan put in
The balanced XLRs
Both of the above
One or more of the digital outs
The factory RCAs that no longer work ;)
Modwright Transporter... on the outs
0 Members and 1 Guest are viewing this topic. Read 2008 times.
funkmonkey
« on: 27 Dec 2009, 11:23 pm »
Thought it might be interesting to see how we have our Transporters hooked up.  8)
I'm using the RCAs into a Modwright 36.5 pre amp, and then using the two pairs of RCA outs on that to feed 4 channels of a Parasound Halo A51 to bi-amp my HT3s.
   Also, I may be experimenting with using both balanced and single ended outs (one set to my 36.5, and the other to a separate headphone amp or possibly my AVR) to allow me to use the Transporter as a source with a pair of headphones, as well as through my two channel system without having to swap any wires around.
« Last Edit: 28 Dec 2009, 03:07 am by funkmonkey »
zybar
Re: Modwright Transporter... on the outs
« Reply #1 on: 27 Dec 2009, 11:30 pm »
Balanced XLR (AQ Panther) to a Plinius M8 preamp, which is connected via balanced XLR  (VH Audio Symmetry)to Atma-Sphere MA-1 amps.
George
« Last Edit: 28 Dec 2009, 03:20 pm by zybar »
Bigfish
« Reply #2 on: 27 Dec 2009, 11:34 pm »
My Transporter is connected via JPS-SC-3 ICS (RCA) to Odyssey Mono SE Amps.
Ken
mikel51
« Reply #3 on: 28 Dec 2009, 04:08 am »
Balanced outs to BAT VK31SE and Balanced to Modwright KWA150.
tdangelo
« Reply #4 on: 28 Dec 2009, 03:19 pm »
mine is connected to my ASR Emitter direct input via JPS Aluminata RCA.
daz_bike
« Reply #5 on: 29 Dec 2009, 10:38 am »
I use RCA out.  I don't have the need for balanced - only running 1m.  I do note that the RCA out seems to be slightly  more direct, with an extra join on the output wiring for the stock XLR outputs. Whether this makes any difference is debatable.
Unless you need XLR due to noise problems or long runs, I would stick with RCA out.
