No variable out - configuration question
0 Members and 1 Guest are viewing this topic. Read 996 times.
mcgsxr
« on: 25 Dec 2009, 10:51 pm »
Well, all this hunting for a new display, and I was assuming that variable outputs were common, as when I bought my 32 inch Vega.
I will buy either the Samsung 42 720p (PN42B450), or the Panny 42 720p (TCP42C1).  According to Best Buy online they both have fixed audio outputs (choice of analog or Toslink).  I am suspicious that the Panny only has Toslink - I could live with it.
I have a old Panny SAXR-25 I use for the 2.1 HT on the main floor - I currently have the TV as the preamp - so all audio and video connections go through the Vega.  That way, my wife needs only to switch inputs on the Vega, and the sound follows - and she only needs to use one remote for the satellite and tv.
I am wondering, would both the Panasonic Plasma and Panny receiver use the same remote codes?  IE, if I buy the Panny, could I connect the Toslink from the Plasma to the SAXR-25 and then teach the satellite to control a Panny device, would the volume then work?
Damn no variable outs!
mcgsxr
Re: No variable out - configuration question
« Reply #1 on: 26 Dec 2009, 03:00 pm »
Well, I placed my bet that all Panny units speak the same remote language, and picked up a TCP42X1 this AM.
It will take me roughly a week to get it hung on the wall, and all sorted out, but looking forward to it.  Pics in time.
