0 Members and 1 Guest are viewing this topic. Read 5742 times.
http://www.amazon.com/2L-Audiophile-Reference-Recordings-Blu-ray/dp/B0025ZITT2/ref=sr_1_1?ie=UTF8&s=dvd&qid=1260996703&sr=8-1-spellDo you use HDMI out or 7.1 analog out?
It looks as if the Oppo BDP-83 will convert this to analog at the 192/24 rate/bit depth.
By any chance you know what Onkyo PR-SC885 does? I am afraid I have not really done my due diligence. I am finally updating my HT and picked up a used unit for processing to go with stock Oppo BDP-83. I only really looked at HDMI switching capabilities. I don't have my 2 channel integrated with HT and my HT is really just for movies and TV. It's a middling system with vintage Polk SDS mains and Aperion center/surrounds powered by Outlaw 770. So I don't necessarily expect true audiophile quality music but I do want to feed them the best signal for HD multi-channel music.
Let me ask you a tough question since you had it. Do you think the DAC/analog output stage in Onkyo is better than the counterpart in stock non-SE Oppo BDP-83?
Quote from: ctviggen on 16 Dec 2009, 09:44 pmIt looks as if the Oppo BDP-83 will convert this to analog at the 192/24 rate/bit depth.Yes, as I stated above. No conversion needed; the Oppo will play the LPCM stereo track natively in 24/192. Oppo's DTS HD MA decoder will, however, only currently support 24/96 (unlike it's TruHD decoder) so the mch from the BluRay disc will be 24/96 in the Oppo. The SACD disc will play with full multichannel DSD fidelity, though.
Alright,I will dig up 8 cables and compare them. I can't just let it sit there if you say analog out is better. Anyway, I am looking forward to watching the BBC Earth/Biography Blu-ray discs on our new 55" with my 7 year old daughter. She loves Discovery, History Channel and National Geographic programs.
Hi Ted,I was interested in the 83 for use ONLY as a transport into the digital input of my MWT using its onboard DAC. I figured I would benefit from a slightly better picture quality (not that its bad) via HDMI from my Denon 3930ci and get to try bluray...?Would I be right in thinking that using digital out only on the 83, there is absolutely no benefit to getting an SE....?Thanks for your helpMark
