Bryston mini mono blocks
0 Members and 1 Guest are viewing this topic. Read 13907 times.
drummermitchell
« on: 10 Dec 2009, 08:15 pm »
I believe this was mentioned quite awhile back, if Bryston has considered  a line
of Bryston mini SST2 mono blocks.
Besides all the bigger monos 7s+28s,I think some mini monos would be Superb.
I know I'd buy a few for my surrounds and maybe split my main speakers,
bigger monos on the bottom and two more minis for the top,just cause we can.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston mini mono blocks
« Reply #1 on: 10 Dec 2009, 08:27 pm »
How much power?
james
drummermitchell
« Reply #2 on: 10 Dec 2009, 10:40 pm »
Hi James,perhaps 150 and up to say 300 -400
I was thinking it would be nice to have just a smaller single channel amp than
having say a 3Bsst(2channel)in one box.
I do know you have the power pacs,but having that in a cabinet with a faceplate,to me would be quite nice I think.
Yet again,maybe there is no demand for such a pc :scratch:..
alexone
« Reply #3 on: 11 Dec 2009, 07:57 am »
good idea, drummer! mono versions of the 2b, 3b and 4b in a "sst2-c" style would be nice...
al.
Hififreak
  • www.brystonheritage.com
    • www.hififreaks.nl
« Reply #4 on: 11 Dec 2009, 08:59 am »
Why not!
4Be mono's.
drummermitchell
« Reply #5 on: 11 Dec 2009, 01:58 pm »
And then make her half as wide and perhaps not as deep.
First watt same as the last,only in a compact chassis.
They'd look pretty classy in smaller systems or in any system for that matter.
Maybe with those mini Maggies 8).
Robert D
« Reply #6 on: 12 Dec 2009, 02:44 am »
Don great Idea
My Wife would Kill me
Robert
drummermitchell
« Reply #7 on: 12 Dec 2009, 03:12 am »
Robert just say it's for her :roll:.Really dear I thought you'd like it ,that's why I bought it.Just look at those mini monoblocks,aren't they cute :thumb:.
Stu Pitt
« Reply #8 on: 12 Dec 2009, 04:03 am »
I think they'd be pretty cool.  Kind of like the Marantz monos a while back, only without sounding and breaking like Marantz!!!
drummermitchell
« Reply #9 on: 12 Dec 2009, 04:29 am »
I remember those Marantz,compact ect.I could see Brystons 12"wX6"hX10"d with handles.Would look and sound superb in an office or den setting or the wifes sewing room :scratch:.
Stu Pitt
« Reply #10 on: 12 Dec 2009, 04:32 am »
Or my main room  :thumb:
« Reply #11 on: 12 Dec 2009, 02:14 pm »
A 2B and 3B monoblocks are really great!!
However a bigger chassis is always better than a small, due more space between the parts and less electrical interferences.
I look forward to this releases...
sfraser
« Reply #12 on: 12 Dec 2009, 07:44 pm »
They are maybe not in the form factor you are looking for, but would'nt the Bryston Power Pac's fit that bill?
srb
« Reply #13 on: 12 Dec 2009, 08:11 pm »
alexone
« Reply #14 on: 12 Dec 2009, 08:29 pm »
...the PowerPacs are not SST2 (yet).
al.
drummermitchell
« Reply #15 on: 12 Dec 2009, 08:58 pm »
I have seen the powerpacs,but I do like the faceplate handles look,eye candy+
performance :thumb:.I suppose a special order is out of the question.
I could only imagine the price as to the extra work involved, everything would be basically half the size.
Robert D
« Reply #16 on: 13 Dec 2009, 02:38 pm »
Don  :scratch:
You dont think
Smaller would cost more.
Robert
drummermitchell
« Reply #17 on: 13 Dec 2009, 04:08 pm »
Hi Robert,it might as they would be a specialty item.
I'm no technician but taking half of a 3b-sst or 4B-sst and making it into a mono block(which I believe both have total separate power supplies),
I imagine making a smaller chassis and the extra messing about with the electronic side of things might make her a bit more money,maybe,maybe not.
Not every body has space for separate amps,especially fullsize mono blocks as
they will go with a 2,3,4 or 14 for what space will allow or that they like 2channel,which we need for stereo.
It would be a specialty item for sure,wish I could take a pict of a Bryston amp
and compress the width of her 19" down to 10-12" and add maybe an inch of height and shorten the depth.
They would work well in small rooms(I have one)they would like superb and with one channel of a 3Bsst or 4bsst you definately wouldn't be hurting for
power all in a compact package.
Robert can you visualize your 4B-sst2 half the width,an inch higher and maybe 6" shorter(WITH HANDLES).Quite visually appealing I think.
Besides having enough power they would be very attractive and I bet your wife would like a couple as mine would also and they can lift them :thumb:.
werd
« Reply #18 on: 14 Dec 2009, 01:29 am »
I liked the idea at first too. But now with sst/sq "first to last watt philosophy" it kinda puts to rest the need for lower watt power amps. I guess their might be a budget issue that could sell them but i dont think they are needed sonically.
vegasdave
« Reply #19 on: 14 Dec 2009, 05:40 am »
Why not!
4Be mono's.
Is that for real? How long were those made?
