Bryston mini mono blocks
0 Members and 1 Guest are viewing this topic. Read 13906 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston mini mono blocks
« Reply #40 on: 27 Dec 2009, 08:46 pm »
I've been wishing for a more cosmetically pleasing version of the power pacs for quite some time for the simple reason of getting the amp as close as possible to each speaker in my 5.1 system, thus minimizing the loudspeaker cable length.  The power pacs would do the trick, but they aren't very attractive.
Hi CDinsmore,
Yes the Power Pacs have been very successful but the original intent for them was as a packaged amp to attach to the rear of a PMC speaker. They kind of took on a life of their own as others started using them as mono versions of our 2B,3B and 4B amps.  Maybe a 150 watt nice looking monoblock would do well. I will rattle the appropriate chains.
james
HooStat
« Reply #41 on: 19 Sep 2010, 11:14 pm »
Did this ever gain any traction?  Would be a nice thing to have.
drummermitchell
« Reply #42 on: 19 Sep 2010, 11:39 pm »
I'd buy a pair of compressed chassi 3b or 4b monoblocks,I'd use them in a smaller system or biamp.
Eye appeal also.
alexone
« Reply #43 on: 20 Sep 2010, 06:31 am »
there are the PowerPacs available (not SSTsq yet...). i think it would be cool to see them in a "real" chassis as an eye candy... sex sells, eh! :green:
however- monoblocks and/or 3 channel versions in addition to all the 2 channel amps would give better choice for any specific setup.
al.
Robert D
« Reply #44 on: 20 Sep 2010, 12:20 pm »
Eye appeal also.
Don  :scratch:
You dont think
Smaller would cost more.
Robert
drummermitchell
« Reply #45 on: 20 Sep 2010, 12:42 pm »
Hi Robert,it probably would,but for eye appeal,it would be worth it to me,
they'd look so darn cute,that even the wife would accept them,a winner I believe :thumb:.
A few hundred watts would be fine for a smaller system.
I see the same chassis but about half the size of what we have now,if I can see it in my minds eye
then perhaps it will become reality,custom order perhaps,that would be pricey.
rmurray
« Reply #46 on: 5 Jun 2011, 12:58 am »
Yes once again, any possiblity of these as monoblocks. Thanks again : :thumb:
pmcfb1
« Reply #47 on: 10 Jun 2011, 06:14 pm »
   I too would like an update on this :D
« Reply #48 on: 11 Jun 2011, 11:12 am »
Hi Guys,
Sorry nothing in the works - I am up to my ears in other projects.
james
Stu Pitt
« Reply #49 on: 11 Jun 2011, 02:14 pm »
Care to share any info on what's to come?
danman
« Reply #50 on: 12 Jun 2011, 02:12 am »
Like the sound of what you said that you are really occupied with other projects James!!!! Sounds like the future will be bright!
Alpha10
« Reply #51 on: 14 Jun 2011, 06:52 pm »
Hi Guys,
james
Hopefully the BDB-1 (Bryston Drive Bay) to go with the BDP-1  :drool:
Got to keep hoping  :D
Cheers
