Total Members Voted: 17
0 Members and 1 Guest are viewing this topic. Read 2657 times.
Kind of difficult to answer given the way you posed the question.I have separate rooms and if you can then go for it. Treated differently and equipped differently.I cringe a little at "receiver" with any Salk speaker. If I had to go receiver then I'd chose the ST's and enjoy them.Widescreen or projector? If projector then maybe a transparent screen? Gives more center choices.All the time I have to answer right now.
I'm currently putting together a new 2 channel sound system, that is also used with my projector for movies.Salk HT2-TLAVA Ultra 550 AmpAVA Ultra SL PreampAVA DACOPPO BDP-831. Turn my 2 channel audio system into 5.1 by adding Salk Veracity center and surrounds, a couple subs, and a receiver. Use this system both for movies and dedicated 2 channel audio.
My original plan was to run HDMI from my blu ray to a receiver. Take the front pre outs of that into an input on my AVA preamp. Then i'd just have to set the receiver up, memorize the volume location on the preamp, and use the receiver for volume control of all speakers. I'd also still be able to get 2 channel audio with the receiver turned off.I just bought the SL preamp. For this confirguration I didn't see a benefit for the EC, but i might be missing something.
I'm thinking it might be better to have a seperate 5.1 system with my projector, and have my 2 channel system in a different room.
