0 Members and 1 Guest are viewing this topic. Read 9544 times.
Thanks for the reply, I am using the Logitech SB3.My issue is that I have a collection that has been assembled from a couple of different sources, with differing naming conventions - is there a s/w solution to rename everything to a specific format and tag it all etc?
Another choice is Squeezebox Server from Logitech - it is free as well and can be used standalone or with streaming devices.
How exactly does Squeezeserver function standalone? I have a Duet in another room, but sometimes want to play music while sitting at my computer. I can't figure out a way to use the Squeezeserver program on my desktop to play music on my computer. I've been told that it's impossible and that I need to buy another SB Receive - which seems kind of silly.
Any update on this?I am pushing all my music onto a recently purchased 1TB external drive, and could use a program to go in and properly tag all the tunes. The naming convention is not all the same etc.Is this my solution?
You need to download SqueezePlay
Ooo, news to me. I'll look into it when I get a few minutes. Thanks!
File naming is generally a secondary issue. It's the internal metadata tagging that is most important, and is what most playback software uses. After you get tagging such as artist names, track numbers, song and album titles correct, you can easily use software to rename files and directories as you like, based on the tags.Try Mp3tag. A fantastic tagging program that can be scripted to do a million different things. If needed, it can also retrieve tagging info from a couple of different web sources, but I'd reserve that for files that either have no tagging at all or are totally wrong. It can rename files from tags, or populate tags by parsing the file names.
I am using mp3tag but find I have to do each cd individually and it takes quite a few minuets. when I select the cds tracks I just ripped it will then provide a list of cd versions for me to pick from. Is this the only way to do it or will it do say 10 selected cds all in a row by itself overnite?
Download link: http://downloads.slimdevices.com/nightly/?ver=7.5SqueezePlay is the most recent 'software' player for Squeezebox Server, that can be run on a computer to play back music streamed from Squeezebox Server. It's essentially a Squeezebox Touch (or Radio) emulator. It's beta software, but it works well enough.Be aware that one thing that none of the software players do very well is maintain synchronization with other hardware Squeezebox players. Sometimes it works OK, not always.Of course, you don't have to use Squeezebox Server at all if you just want to play music from your local network. You can just browse to the files on the server and play them through Winamp or foobar or some other music player.
