Music file organizing software
0 Members and 1 Guest are viewing this topic. Read 9647 times.
JEaton
Re: Music file organizing software
« Reply #20 on: 21 Apr 2010, 02:06 pm »
Tried to download the Windows version, but got an error saying the file is corrupt.  Please advise.
Worked fine for me just now. Try again.
BobC
« Reply #21 on: 21 Apr 2010, 02:09 pm »
"Error: The setup files are corrupted. Please obtain a new copy of the program."
BobC
« Reply #22 on: 21 Apr 2010, 02:10 pm »
Just click on SqueezePlay-setup.exe, correct?
I have Squeezecenter 7.5
Thump553
« Reply #23 on: 24 Apr 2010, 01:43 pm »
I am using mp3tag but find I have to do each cd individually and it takes quite a few minuets.  when I select the cds tracks I just ripped it will then provide a list of cd versions for me to pick from.  Is this the only way to do it or will it do say 10 selected cds all in a row by itself overnite?
I run across this a lot.  I think it is because mutliple tag versions of the same album are uploaded to the internet tracker.  If that's the case then it doesn't matter which software you use, all will have the same problem.
I'm a fan of EAC and mp3tag.  I used Mediamonkey for a while but it was getting bogged down and I eventually dumped it when it's database got corrupted.  As someone said earlier, it is the tagging convention that is critical, not the file naming system
« Reply #24 on: 24 Apr 2010, 02:18 pm »
thanks for the update.  I guess I just take my time and rip and tag as I go.
BobC
« Reply #25 on: 26 Apr 2010, 01:23 pm »
Tried it again and this time it worked!   :D
Anyone know how to make the screen larger?
Hoots
« Reply #26 on: 4 May 2010, 12:34 am »
I use J River Media Jukebox.  I have used Meedio, MediaMonkey, Foobar, and others in the past.
I use it to organize, tag, play and xfer to portable.  It has ASIO support and lot's of customization for sorting and displaying.
I currently have 700GB of FLAC from my large CD collection.
I have posted screen shots and a description of how I use it here:
http://yabb.jriver.com/interact/index.php?topic=50885.0
For cataloging my vinyl and CDs I use Collectorz.
kenreau
« Reply #27 on: 21 May 2010, 06:12 pm »
Bumping this, as I am also looking for a software solution for an existing music folder with legacy files.
I have a dedicated 1TB drive with my master music folder that has grown over the past 5 years.  It has a mix of albums with early backups of .wav files without album artwork or tags all the way up to current / recent backups using dbpower amp in flac format.
Is there a software solution that can scan an existing music folder and add all necessary/missing album artwork and tags?
Kenreau
doctorcilantro
« Reply #28 on: 21 May 2010, 06:21 pm »
Look into J. River. Very powerful. Very easy to manually add cover art for what can't be auto-tagged. Apps that use MusicBrainz database can help to tag stuff not found in J. River database for tagging.
May be limitations if you go with the free Jukebox version. the full version is worth easily twice as much as what they charge.
Thump553
« Reply #29 on: 21 May 2010, 08:31 pm »
I use an Excel spreadsheet I turned up. Originally it was for a book collection, but I modified it a bit.  It's fairly rudimentary-I just list artist, album title and DVD # that I burnt my FLAC files backup to, but it does the trick so long as you keep it up.  If anyone is interested in the template, send me a PM and I can shoot it your way.
