Tube signal generator
0 Members and 1 Guest are viewing this topic. Read 1772 times.
mackortoyota
« on: 21 Nov 2009, 12:20 am »
I found a tube op-amp circuit, and was needing it to oscillate at 10khz, and remove s semiconductor from it. I was thinking of a phase-shift oscillator, but wein bridge could work as well. http://www.forsselltech.com/downloads/schematics/VT%20Opamp.PDF
mackortoyota
Re: Tube signal generator
« Reply #1 on: 22 Nov 2009, 02:43 am »
I'm getting a tube oscilloscope in a month or so, and wanted a signal generator of similar internals to go along with it. I'm a big fan of vintage equipment...
mgalusha
« Reply #2 on: 22 Nov 2009, 04:03 pm »
The Forssell opamp circuit is pretty cool but personally I would keep the current source on the tail of the diff amp, maybe even add a second device to increase it's effectiveness.
I've never had occasion to build a vacuum tube oscillator but if needed I would pull something out of the Radiotron Designers Handbook or another old textbook. No need to re-invent the wheel for that. Pete Millett has a bunch of them scanned in available for download. http://www.pmillett.com/technical_books_online.htm
Also, there is a ton of stuff on the DU web site. http://mysite.du.edu/~etuttle/electron/elecindx.htm
mike
mackortoyota
« Reply #3 on: 23 Nov 2009, 04:12 pm »
For some reason, firefox crashes every time I try and download from that site.
Anybody here know why?
mgalusha
« Reply #4 on: 23 Nov 2009, 08:46 pm »
Which site? I use FF for both without any problems. Pete's site is pretty slow, so perhaps it's possible FF is becoming non responsive while it's waiting.
mackortoyota
« Reply #5 on: 24 Nov 2009, 01:29 am »
Pete's site. I can view datasheets on his site with no problems, but the large files of the book either produce an error and it stops loading, or it locks up and crashes. Latest version with default settings, running on xp (also factory) so maybe that's why. I should be able to view them in a month though.
mgalusha
« Reply #6 on: 24 Nov 2009, 09:37 pm »
I never try and open PDF's inside of a browser, which it sounds like you're doing. Save the file and then open it, should work much better. Assuming my guess is right of course. :)
mackortoyota
« Reply #7 on: 25 Nov 2009, 02:13 am »
Tried both. When I get a new laptop, I'll be running linux, and can fool around with the firefox settings.
