Nuh-uh. You are NOT putting that thing there. Not in MY (fill in the blank).
Though my room is somewhat rectangular, its hardly typical, methods that tie placements to a set formulae does not apply in my case. MasterSet which does not require rigid measurements, works for me because its works with the room you have...
I cannot in the audio/Living Room as it is oddly shaped with no two walls even close to being the same with openings all over the place, plus cathedral ceiling, plus a fifth wall (free-standing) to boot. Therefore I've complied with the WAF math method instead. This is the basic formula: QuoteNuh-uh. You are NOT putting that thing there. Not in MY (fill in the blank).This formula is universal - just fill in the blank - as it applies not only to all rooms in the house, but also in the bedroom.
I'd be seriously interested in what your room dimensions and speaker locations are. And what kind of speakers you have.
Quote from: rockadanny on 21 Nov 2009, 12:04 amI cannot in the audio/Living Room as it is oddly shaped with no two walls even close to being the same with openings all over the place, plus cathedral ceiling, plus a fifth wall (free-standing) to boot. Therefore I've complied with the WAF math method instead. This is the basic formula: QuoteNuh-uh. You are NOT putting that thing there. Not in MY (fill in the blank).This formula is universal - just fill in the blank - as it applies not only to all rooms in the house, but also in the bedroom. You crackin me up, dude. Good post.For sure, placement within the room and the room itself is fundamental to achieving the best from our systems. I have to be careful in my small room (15x12x8) that the lower midrange doesn't get too bloomy so my equilateral triangle is somewhat larger than Cardas recommends and the distances from the walls behind my seat and my speaks are different from one another. I know some guys don't or can't experiment with this. If you can, do it. Even the degree of toe in can matter. Use a tape measure or a laser gizmo or something and record where you've been. I'd even go so far as to recommend that a person makes notes about what they notice at this or that location with or without criteria.
QuoteI'd be seriously interested in what your room dimensions and speaker locations are. And what kind of speakers you have.My room is about 11 1/2- 9 1/2 W. X 15 1/5 L. The width varies every 5ft. starting at the front wall(where my stereo is located) and ending up the narrowest at my sitting position. The varying wall is the right wall. Behind my seating position is a big opening (no door, just a curtain with bookcases creating a sort of short hallway)to my bedroom. Right wall is the wall to outside, its a brick wall with plaster. Left wall is inner wall of the apt. building with the apt. entry door, and next to that the bathroom and to the front the kitchen(ette). This is a typical Brooklyn apt. The kitchen is so small that I have to put my fridge at the entry to the kitchen, ie in the stereo/HT room, and it takes up about 3ft. of the width of the front of the room. So there goes any resemblance to a rectangular shape.Plus there are other shelving units crowding the corners at the listening end. Ceiling is a nice height about 9 1/2 ft. Speakers are about 53(L) and 55(R) inches from front wall and about 40/43" from sides walls, bearing in mind that there are objects filling those spaces. They are about 5 ft apart and I sit about 7-8 ft away. Speakers are VMPS RM1, my gallery has a few shots of my system but not in the current location(speakers ie). As you can see none of my measurements are uniform...I get a nice centered image that remains anchored regardless of whether I shift my seat 2 ft. to left or right. I lose a little sparkle in the highs when I stand up, but that is the character of this speaker model. The soundstage is about 6ft deep behind the speakers, and I get a nice wide envelope sound effect with sounds sometimes emanating from my left and right.
Quote from: jimdgoulding on 21 Nov 2009, 02:04 amQuote from: rockadanny on 21 Nov 2009, 12:04 amI cannot in the audio/Living Room as it is oddly shaped with no two walls even close to being the same with openings all over the place, plus cathedral ceiling, plus a fifth wall (free-standing) to boot. Therefore I've complied with the WAF math method instead. This is the basic formula: QuoteNuh-uh. You are NOT putting that thing there. Not in MY (fill in the blank).This formula is universal - just fill in the blank - as it applies not only to all rooms in the house, but also in the bedroom. You crackin me up, dude. Good post.For sure, placement within the room and the room itself is fundamental to achieving the best from our systems. I have to be careful in my small room (15x12x8) that the lower midrange doesn't get too bloomy so my equilateral triangle is somewhat larger than Cardas recommends and the distances from the walls behind my seat and my speaks are different from one another. I know some guys don't or can't experiment with this. If you can, do it. Even the degree of toe in can matter. Use a tape measure or a laser gizmo or something and record where you've been. I'd even go so far as to recommend that a person makes notes about what they notice at this or that location with or without criteria.Oh, I left out measurements . . My speaker cabinets, Meridian M20 actives not made for a long time, are 7" wide and 14.5" deep and from the front centerpoint of my cabinets they are 52" off the wall behind them and 35.5" from the side walls (73" apart). My head is 48" from the wall behind me. The wall behind me opens on to a diagonal staircase and on the one side where it joins with the sidewall sits a shallow secretary w/o glass doors as a diffusor (I even stagger the drawers). Two GIK panels rest along the side walls in front of the plane of my speaks. The net gain is a stage that belies my room size in the best way possible . . breadth and depth of field. Imaging is vibrant and palpable aided by an ARC tube pre and, well, you know .
I'm familiar with Cardas' math, thanks. But, its been a long time so I may give it another go over the weekend. There may be a place inbetween Cardas' configuration and your side walls that you haven't hit upon yet. What dipoles are you using?
I think the Cardas Method is certainly valid for one piece speaker systems. Like most others though, it is sometimes a compromise between attributes, such as best low end response, best imaging etc. There seems to be very few absolutes and universal approaches in audio. There are just too many variables.For my two piece speaker system I have found that the Audio Physics Speaker Placement Method works best for my room and system.http://www.audioasylum.com/scripts/d.pl?audio/faq/audiophysic.htmlIn a way the bass towers are following a similar Cardas plan, but the higher frequency units and listening position are not.The beauty of such a two piece system is that it is nearly infinitely adjustable in just about every way, but the big problem with that has to do with it being nearly infinitely adjustable in just about every way .Although I love big speakers and the visuals they present, I don't want to localize them once the music starts. I want them to completely disappear. My current set up does thit for me. My upper frequency speakers are about 8 feet apart along a 21 foot wide front wall, yet the presentation can stretch from side wall to side wall if the recording permits.
