Your room is awesome! Nice job with the DIY room treatment too. Those coverings look really, really good in that room. I have no idea about placement for multi cabinets but I'm familiar with the AP method. I used it to great affect when I had some direct radiator monitors placed on the long wall in a pseudo nearfield configuration. Great dynamics and a very, very wide and seamless wall of sound, but over the long haul I found it too in my face. And it was too wide but not deep enough, too exaggerated from a recording space dimensions point of view. It doesn't look like your setup is really nearfield at all and I am surprised that the AP method works in that room but since you have multiple cabinets all bets are off! Once again, very nice looking room.
HousteauIs the Audio Physics setup similar or identical to Allen Perkins' Immedia? IIRC Allen is the ex-importer for AP.
They are dipole from about 280 Hz on up and their dipole nature is adjustable by the means of a foam wedge inside of the rear facing horn. I have actually removed that wedge completely and use instead 6' 12" round tube traps. Their position behind that rear facing horn design, as well as the placement of the artificial plants around them helps greatly in sculpuring the sound I want.
Are those the ASC tube traps with the adjustable deflector?
I hear that diffusers are supposed to be great on the front wall with dipoles. A deflector might be good too, and the ASC's do absorption too which should be a bonus.
Quote from: mjosef on 21 Nov 2009, 01:42 amThough my room is somewhat rectangular, its hardly typical, methods that tie placements to a set formulae does not apply in my case. MasterSet which does not require rigid measurements, works for me because its works with the room you have...I've heard of the Masterset placement method and was intrigued by it because a lot of all the reports of great results.Bryan
As I've read many of the posts here I read the term "better" a lot, without any kind of reference to what better is. My own experience has shown that every little speaker move will change the sound you hear. If you tweak the positioning of the speakers and constantly hear "different" sound, what is your reference for "better".
Hello,I caught this thread in a Sunday morning browse thru of the forums. I don't think I've ever posted in this one, being mostly on the Aspen Circle.I've used just about every method of setting speakers in a room. Methods such as Audio Physic and Cardas are stricky mathmatical. AP does at least try to offer an explanation, while Cardas just throws out the numbers with nothing really. I've used both methods. Both will give you a small narrow sweet spot of listening, and if you either move yourself or the speaker just a little bit, the sound changes.As I've read many of the posts here I read the term "better" a lot, without any kind of reference to what better is. My own experience has shown that every little speaker move will change the sound you hear. If you tweak the positioning of the speakers and constantly hear "different" sound, what is your reference for "better". I think most all folks don't really have a reference, instead it's all just a guess as to what seems to sound best.I'm a big Master Set fan, have taught myself to do it, and can do it reasonably well.Master Set is based on the principal that the sound you hear from loudspeakers is based on the amount of sound pressure the speaker puts into the room, rather than the distance you, the listener, sit from the speakers.In order to accomplish the above, each speaker must sit in a position to be in perfect and equal phase with regards to the other speaker so that the two speakers act as one sound source into the room.Once you hear a well done Master Set, you never want to listen to a set up any other way.Well, at least that's the way it was for me.
