MDF vs Baltic Birch?
0 Members and 1 Guest are viewing this topic. Read 5542 times.
earplay
  • Do ya feel... lucky?
« on: 18 Nov 2009, 03:13 am »
I've got an old pair of 2-way speakers in a simple sealed box or monkey coffin, as I've heard them called.  :lol:
Would it be worthwhile to replace the MDF monkey coffins with Baltic Birch monkey coffins? Is there enough acoustic difference between these materials to warrant the time and expense? Would you do it?
Re: MDF vs Baltic Birch?
« Reply #1 on: 18 Nov 2009, 03:21 am »
Use a layer of each.  Since both materials have different resonant frequencies, you end up with a more acoustically inert enclosure.
JoshK
« Reply #2 on: 18 Nov 2009, 03:29 am »
In my opinion, not worth rebuilding.  But if starting a new project, the BB is worth the extra money IMO if for nothing else that it a lot less dust everywhere and the dust isn't as harmful.   Its also lighter, but not a great deal.   Its rigid and faster to dissipate energy aparently but at the same time resonates in the audio range.  Which is worse?  Potentially more audible but fast time decay or less audible but longer decay?
I also think that BB is nicer to work with but can chip out a bit (small chips infrequently), so some bondo might be needed before veneering or painting.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #3 on: 18 Nov 2009, 07:30 am »
What speakers are they? Pictures? (including insides)
Here is a long discussion that goes into some detail on a speaker building strategy that optimizes for good multiply.
Read this post 1st, it puts a lot of the discussion in perspective.
dave
Wind Chaser
« Reply #4 on: 18 Nov 2009, 08:39 am »
Speaking from experience, I could not hear a difference in the sound between the two materials on the same speaker.  MDF is easier to work with IMO.  If you want to build an enclosure with real acoustic merit, use aluminum or stainless steel.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #5 on: 18 Nov 2009, 09:08 am »
It doesburn nicely if you get the "bonfire" hot enuff.
dave
earplay
« Reply #6 on: 18 Nov 2009, 06:07 pm »
The speakers in question are Monitor Audio 852's. They have a 6' woofer and silk dome tweets.
I just replaced the crossover cap with Russian mil teflons and upgraded the wires. Wow! Their sound is just tremendous. I've been using single driver horns and had been thinking of giving the MA's to my nephew. No way, now!
The highs are smooth and the bass is articulate giving me a new appreciation for old designs aided by new components.
I probably won't mess about much more with these speakers, but I wondered if birch boxes would yield a worthwhile improvement.
One thing I came across was the notion of installing the tweets on a compliant mounting ala the Roksan Darius.
face
« Reply #7 on: 19 Nov 2009, 01:14 am »
After recently working with BB, I doubt I'll go back to MDF.  The only problem for me is availability.
Pez
« Reply #8 on: 19 Nov 2009, 04:03 am »
If you're going to rebuild the cabinet you may as well go all the way. Redesign it from a square box to a tear drop shape using layered MDF. You can pretty much do any shape you want with this method.
doorman
« Reply #9 on: 19 Nov 2009, 05:21 am »
For those who do use MDF, beware the nasty dust!
Don
Wind Chaser
« Reply #10 on: 19 Nov 2009, 08:18 am »
Wear a mask and eye protection, especially when working with the router.
sts9fan
« Reply #11 on: 20 Nov 2009, 02:52 pm »
Where do you guys buy your BB?
Wind Chaser
« Reply #12 on: 20 Nov 2009, 09:58 pm »
Plenty of it in Canada at any place that sells lumber.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #13 on: 20 Nov 2009, 11:18 pm »
Not anyplace... we can't get it at the local 7-11 (oops mean the Home Depot just down the hill) or at Rona. We get it from one of the specialists, like Windsor Plywood. A whole thread on the subject over on diyA.
dave
Wind Chaser
« Reply #14 on: 20 Nov 2009, 11:19 pm »
Well you must be living on an island. :lol:
face
« Reply #15 on: 20 Nov 2009, 11:44 pm »
What are you trying to say?   :icon_lol:
So far I've only found one place on Long Island.  I wish they would cut the boards in half for me, it's a pain to lug full size boards 20+ miles home.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #16 on: 21 Nov 2009, 12:05 am »
Yep. Independent Republic of Vancouver Island. When we seceed we want everything Manitoba West :)
dave
