Does anyone know where to source replacement toggle switches from for SWL9.0SE ?
0 Members and 1 Guest are viewing this topic. Read 1836 times.
Marc B
I need a replacement power switch for the SWL9.
Does anyone know where they are from and the part number ?
cheers
Marc B
Try this web, 20% on sale
http://www.partsconnexion.com/controls_toggle_switch.html
they aren't the same kind of switches
this is what I'm after
cheers
Norman Tracy
    • Audio Crafters Guild
I would strongly suggest contacting ModWright and getting a replacement from the factory. The are tens to hundreds of manufacturers who make switches like that pictured each offering options like normially open, normially closed, spring loaded or latching. My opinion is it is worth a few extra bucks to pay ModWright's overhead to avoid the crap shoot of trying to reverse engineer the part.
Marc B
When I try and contact them I get this reply..
I'll be more likely to see your email and future messages if you are on my priority Guest List.
Click here to be put on my Guest List
Thank you,
and the supplied link doesn't work.
I received 1 email from Dan who asked for a picture of the switch but heard nothing since. That was 2 weeks ago.
I don't know if the switch has been sent or not , I didn't receive confirmation that he received my email with the picture on or anything.
My power switch has a broken connection inside due to some damage from the courier (it wasn't purchased brand new). I've managed to butcher it do make the circuit but now the preamp can only be powered down by pulling the cable from the rear.
As you can imagine , this is less than ideal and I'd like a replacement switch. I'm not fussed on where it comes from or how much I have to pay for the thing. I'm just a bit frustrated that I can't actually get hold of the manufacturer to order the part, never mind find a suitable replacement anywhere online.
I'm located in the UK.
cheers
Marc B
nevermind, managed to contact Dan via telephone and hopefully sorted a replacement.
