Crossover Question
0 Members and 1 Guest are viewing this topic. Read 1974 times.
russe41
Crossover Question
« on: 11 Nov 2009, 10:59 am »
Thinking of actively biamping my vr4hse's with ss, tubes and a 3way x-over.
How much work is it to get to the internal crossover for the m/t as well as the bass unit? And are they straight forward connections, from binding posts to the crossover to the drivers? Also,is the woofer units wired in parallel?
     Russ
es347
  • ..I've got my eye on you...which one you say?
Re: Crossover Question
« Reply #1 on: 11 Nov 2009, 01:48 pm »
Seems almost sacreligious :lol:
Hoosierdaddy
« Reply #2 on: 11 Nov 2009, 07:23 pm »
russe41
« Reply #3 on: 11 Nov 2009, 09:19 pm »
Yes i've seen this before. It will be totally reversible if the results aren't stellar.
And everything else I've  read for electronic xovers seem to far outweigh any
issues associated with it.
McTwins
« Reply #4 on: 12 Nov 2009, 07:39 pm »
Hi
I am using active x-over between my pre and amps and it works great here.
SundayNiagara
« Reply #5 on: 13 Nov 2009, 01:18 am »
Agreed!
es347
« Reply #6 on: 13 Nov 2009, 03:28 am »
Agreed!
Sort of like putting Uniroyals on a Ferrari. :o
SundayNiagara
« Reply #7 on: 14 Nov 2009, 12:20 am »
Agreed!
Good one!  Reminds me of people buying $15k speakers and then can't place them properly.
