Anyone using an HD ant (Winegard?) for local channels?
0 Members and 1 Guest are viewing this topic. Read 10372 times.
Phil A
Re: Anyone using an HD ant (Winegard?) for local channels?
« Reply #40 on: 4 Jan 2010, 02:40 pm »
If you go to amazon.com and enter a search for "hdtv tuner box" it will come up with a few things.  I have a couple of Samsung SIR T150s (actually just using one at the moment on the PC monitor).  I have them for emergency spares more than anything.  I bought a DTB-H260F when it was new for the main system and picked up an open box from Best Buy about 6 mos. back or so for $50.  So I put it in the basement system (still have not removed the old SIR T150 but probably will eventually - it's OK for a back-up).  I actually have two antennae in the attic as from my location I pick up DC and Baltimore HD and one station is in a slight different direction and I use a small UHF bow tie and have an A/B switch in the main system.
