Dynaudio Audience 72 spikes? (Somewhat acoustics related...)
0 Members and 1 Guest are viewing this topic. Read 3189 times.
knut_the_viking
Hello,
I just picked up a bargain pair of Dynaudio Audience 72 floorstanders.
Excellent condition, but no spikes included.
Does anybody know if these were sold with spikes?
There are brass nuts in the corners of the base, so they look prepared to have spikes screwed in.
Can anybody suggest a place to get my hands on some suitable spikes? The speakers will be placed on regular carpet, pile depth about 1/2 - 3/4 inches(I guess)
Thanks in advance
Knut
« Last Edit: 12 Nov 2009, 05:24 pm by knut_the_viking »
timind
  • permanent vacation
Re: Dynaudio Audience 72 spikes? (Possibly wrong circle)
« Reply #1 on: 5 Nov 2009, 01:10 am »
Unless you need to spend a lot of money, maybe something here would work http://shop.ebay.com/ronays-tweaks/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Don't know this seller but have purchased identical spikes. If you can here the difference one spike makes over another your hearing is better than mine.
knut_the_viking
« Reply #2 on: 5 Nov 2009, 02:10 am »
Thanks! I'll look into these.
It's more a need to make the speakers stay put, as the soft carpet makes them quite unstable.
I also doubt I will be able to hear much difference in sound.
timind
« Reply #3 on: 5 Nov 2009, 02:50 am »
Parts Express is another seller. I put these under my subwoofer http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-718
knut_the_viking
« Reply #4 on: 9 Nov 2009, 08:54 pm »
A trip to the hardware store later, and after trying a number of different thread size bolts, I find that the bolts are metric M8.
Googling for standard Dynaudio spike thread sizes return several (!) sites showing that yes, Dynaudio uses M8 bolts for their spikes.
Why didn't I try that first?   :oops:
