0 Members and 1 Guest are viewing this topic. Read 9765 times.
I would like to power my VERY effecient ribbon tweeters with a tube amp. What do you recommend I look at. Please keep cost resonable. < $1500
How about the new Gary Dodd battery powered tube amp (15wpc) at $995 + batteries and charger? Probably dead quiet for efficient speakers as long as they're 4 ohms or better.... or maybe a Music Reference RM-10 MK II which is a nice amp.
The new Dodd has to go at or very near the top of your list.
i would recommend an almarro a205a mkll.
Quote from: doug s. on 5 Nov 2009, 07:00 pm i would recommend an almarro a205a mkll. I had one of those for a few months. Very nice amp, just not enough "umph" for me.Bob
thanks guys! I got a used Decware off audiogon that I couldn't pass up...this will give me a good "feel" for what the tubes will do on the ribbons. If I ever want to upgrade, shouldn't be a problem selling this beauty.
Quote from: jtwrace on 5 Nov 2009, 07:51 pmthanks guys! I got a used Decware off audiogon that I couldn't pass up...this will give me a good "feel" for what the tubes will do on the ribbons. If I ever want to upgrade, shouldn't be a problem selling this beauty. i had a decware before i got my almarro. the almarro crushed the decware in all performance aspects. but, to be fair, i suspect it was cuz i was using 14 ohm speakers at the time. steve deckert assured me that the decware amp would have no problem whatsoever w/the 14 ohm load of my 97db-efficient coincident wictory's i had at the time, but that wasn't even close to being the case. that amp wanted to see a 4 ohm load, 8 ohm max.doug s.
Just a touch higher than you want to go, but I would seriously consider this:http://www.audiocircle.com/index.php?topic=72057.0
Quote from: doug s. on 5 Nov 2009, 07:59 pmQuote from: jtwrace on 5 Nov 2009, 07:51 pmthanks guys! I got a used Decware off audiogon that I couldn't pass up...this will give me a good "feel" for what the tubes will do on the ribbons. If I ever want to upgrade, shouldn't be a problem selling this beauty. i had a decware before i got my almarro. the almarro crushed the decware in all performance aspects. but, to be fair, i suspect it was cuz i was using 14 ohm speakers at the time. steve deckert assured me that the decware amp would have no problem whatsoever w/the 14 ohm load of my 97db-efficient coincident wictory's i had at the time, but that wasn't even close to being the case. that amp wanted to see a 4 ohm load, 8 ohm max.doug s.OK. According to the Almarro site they only have one amp option which is P-Pmono blocks...two much for what I'm going to use it for. We'll see how the Decware does.
