0 Members and 1 Guest are viewing this topic. Read 9772 times.
Quote from: jtwrace on 5 Nov 2009, 08:25 pmQuote from: doug s. on 5 Nov 2009, 07:59 pmQuote from: jtwrace on 5 Nov 2009, 07:51 pmthanks guys! I got a used Decware off audiogon that I couldn't pass up...this will give me a good "feel" for what the tubes will do on the ribbons. If I ever want to upgrade, shouldn't be a problem selling this beauty. i had a decware before i got my almarro. the almarro crushed the decware in all performance aspects. but, to be fair, i suspect it was cuz i was using 14 ohm speakers at the time. steve deckert assured me that the decware amp would have no problem whatsoever w/the 14 ohm load of my 97db-efficient coincident wictory's i had at the time, but that wasn't even close to being the case. that amp wanted to see a 4 ohm load, 8 ohm max.doug s.OK. According to the Almarro site they only have one amp option which is P-Pmono blocks...two much for what I'm going to use it for. We'll see how the Decware does. http://www.almarro.com/products.htmldoug s.
Quote from: jcoat007 on 5 Nov 2009, 06:24 pmJust a touch higher than you want to go, but I would seriously consider this:http://www.audiocircle.com/index.php?topic=72057.0Frank Van Alstine is moments away from full production on the new Ultravalve amp featuring 6CA7 power tubes, with the 5AR4 rectifier tube, pushing 30 watts RMS per channel. Many reviewers at the RMAF wanted a sample for review, as it would push most moderately effiecient speakers to amazing power strokes. At $1699, it is a true bargin an it also sounds like a 100 watt per channel amp as the bass control is perhaps the best in the industry for a 30WPC tube amp.Wayner
Quote from: doug s. on 5 Nov 2009, 11:30 pmQuote from: jtwrace on 5 Nov 2009, 08:25 pmQuote from: doug s. on 5 Nov 2009, 07:59 pmQuote from: jtwrace on 5 Nov 2009, 07:51 pmthanks guys! I got a used Decware off audiogon that I couldn't pass up...this will give me a good "feel" for what the tubes will do on the ribbons. If I ever want to upgrade, shouldn't be a problem selling this beauty. i had a decware before i got my almarro. the almarro crushed the decware in all performance aspects. but, to be fair, i suspect it was cuz i was using 14 ohm speakers at the time. steve deckert assured me that the decware amp would have no problem whatsoever w/the 14 ohm load of my 97db-efficient coincident wictory's i had at the time, but that wasn't even close to being the case. that amp wanted to see a 4 ohm load, 8 ohm max.doug s.OK. According to the Almarro site they only have one amp option which is P-Pmono blocks...two much for what I'm going to use it for. We'll see how the Decware does. http://www.almarro.com/products.htmldoug s.Yes, that's where I found that they only have one amp...everything else is intergrated. Doesn't work for my system.
Audio by VanAlstine "UltraValve", AVA has a 30 day return peroid, you can't go wrong. It's a great amp for the $$$.
