0 Members and 1 Guest are viewing this topic. Read 3142 times.
I have been using Solid Tech Discs of Silence underneath my Bryston 4B SST2 which is sitting on top of a 2" thick maple block on a maple end table.
A properly designed solid state amplifier (and all of Brystons amps fall clearly into this category) will be unaffected by vibrations coming from the environment. Putting it on soft foam pads or suspending them from springs might make it look cool or might make you imagine it is doing something, but it will not.
Ketih, that whats installed on my Rack Top and BottomDisk of Silence Top shelf Where BCD-1 just sits Spring loaded. Good for heavy foot steps and Dogs jumping next to BCD-1 I call it protection My Wife Dances with her friends in the same Room next to Stereo Stand Ouch.....Feet of Silence 3 heavy springs adjustable per leg of rack Solid as a Rock Only way to go Robert
Quote from: Robert D on 17 Oct 2009, 11:37 pmKetih, that whats installed on my Rack Top and BottomDisk of Silence Top shelf Where BCD-1 just sits Spring loaded. Good for heavy foot steps and Dogs jumping next to BCD-1 I call it protection My Wife Dances with her friends in the same Room next to Stereo Stand Ouch.....Feet of Silence 3 heavy springs adjustable per leg of rack Solid as a Rock Only way to go Robert
