0 Members and 1 Guest are viewing this topic. Read 9950 times.
Barry et al,The Metric Halo ULN-8 has been touted as not only a great sounding 2 channel 24/192 DAC but also could be used as a multichannel DAC for 24/192 each channel!! Wow! Could Barry or someone help guide us as to how this would be set up in a home mch setup. I, for one, have big $$ invested in a dedicated multichannel setup and would love to have the sonics that this could produce. How would multichannel files be assigned to each channel? What would be the source? ThxTed
No, just wondering how an already decoded and/or multichannel music signal would be processed by a multichannel DAC like the ULN-8. 2L, for example, sells downloadable FLAC 24/96 5.1 multichannel files, but not sure how they are handled. Are they 3 files (l/r, c/sub and ls/rs) or what? And what transport or player send them in synch?
So, ripping a mch track via DVDAExplorer, or downloading a 2L 24/96 5.1 FALC file would work (as long as you knew what channels went to what subgroup). In DVDAexplorer it's typically 2 subgroups, one which is lf-rf-ls-rf and one has c-lfe. On the 2L site they say this: "The track order of all 5.1 surround files follows the standard as defined by SMPT/EBU and implemented by SourceForge in FLAC (v. 1.2.1b): L ? R ? C ? Lfe ? Ls - Rs"
If you could determine that the MH ULN-8 could perform the multi-channel conversion, would you consider this lofty acquisition, and would you use it as the DAC for all digital sources?
Yes, the flexibility and functionality of a ULN-8 holds promise for both 2 channel and multichannel music, but can't figure out how I'd use it for movies as the signal path for Dolby TrueHD or DTS HD MA is restricted to HDMI digitally.
Actually my system profile is a bit old. For 2 channel I use both the Modwright tube modded Transporter (via SqeezeCenter) in one system, and I've added a Macbook (internal SSD drive, external USB drive) to firewire Weiss DAC2.
I'm curious if you know anything about the ULN-2. Is it just a channel version of the ULN-8? It looked like it had more conventional connectors, too.
...Well, I think at that high level it must come down to minor preferences...
I used a ULN-2 for years (before that a 2882 and now the ULN-8) and can say I found it to be a fabulous device. I can also say I'd rather have a ULN-2 running 24/96 than a number of 24/192 converters I've heard.
So are you saying for 16/44.1 and 24/96 2-channel playback only use, the ULN-2 has equal sound quality to the ULN-8, or has several years technology improved that aspect?
I see they only mention OS X. So I assume it can't be setup with a Windows machine, or does it need any setup for simple DAC playback?...
Wonder if the Amarra Four sounds as good as the ULN-8.http://www.sonicstudio.com/amarra/amarra_hardware.html
