0 Members and 1 Guest are viewing this topic. Read 3759 times.
For bass absorbers, if you're only going 4" thick, then the 8lb is fine. If you're doing thicker chunks, then 3-4lb density is preferable.Bryan
Quote from: bpape on 16 Oct 2009, 07:35 pmFor bass absorbers, if you're only going 4" thick, then the 8lb is fine. If you're doing thicker chunks, then 3-4lb density is preferable.Bryanthicker is preferable for which parameters? cost, absorption coefficient, lower frequency extension? (I bet you will say all of them )Thanks again...
Wow, nice responses already. If a person were to cut these in half, for a 16x24" rectangle, then cut them in half on a diagonal, then alternate top and bottom so that they are stacked evenly, will this be sufficient for a bass trap going from floor to ceiling? Knowing that the 2 sides coming out from the corner will not be the same length, would you put the long side to the wall going to the back of the room, or inside the 2 corners kind of between the speaker/tv area? Many many thanks to you responders so far.I forgot to add in that the panels were 16x48 inch rolls.
Guys, I don't have a real clue as to what to expect with any sort of traps. To my knowledge I have never heard a system with traps in place nor seen any except on forums where their virtues are extolled.I have seen references to wedges of insulation in a corner and also corner tubes. On a tube, is there any particular diameters that a person should shoot for? And for the wedge idea, is this a floor to ceiling item, or a particular ratio from floor to ceiling? Another question or two is... on a tube do you build a frame inside such as chickenwire or say maybe a used carpet tube to roll it up on, and do you need multiple sizes?
Quote from: Xtatik on 17 Oct 2009, 03:07 pmGuys, I don't have a real clue as to what to expect with any sort of traps. To my knowledge I have never heard a system with traps in place nor seen any except on forums where their virtues are extolled.I have seen references to wedges of insulation in a corner and also corner tubes. On a tube, is there any particular diameters that a person should shoot for? And for the wedge idea, is this a floor to ceiling item, or a particular ratio from floor to ceiling? Another question or two is... on a tube do you build a frame inside such as chickenwire or say maybe a used carpet tube to roll it up on, and do you need multiple sizes?Expect a tightening and extension of the bottom end, an increased clarity in the mids, ease of hearing more details at lower levels, etc.If you want a tube that will perform on par with a 17x17x24" triangle chunk, you're looking at a minimum of 16" diameter - 20" is better.Floor to ceiling if you can. If you can't, do what you can. It's a thickness and surface area game.Bryan
