0 Members and 1 Guest are viewing this topic. Read 6935 times.
For that matter, how would an iPod/Wadia compare to a good CDP like Rega, Cambridge Audio, or Raysonic?
Kirk, iPods will play non-compressed files in the .WAV and .AIFF formats, as well as the Apple Lossless Audio Compression (ALAC) format. Steve
The Wadia is only as good as the compressed files that are loaded to the iPod device. A CDP like the 3 mentioned above play discs in their native format, iPod products will not accept non-compressed files (compressed files = MP3). So utilizing the iPod/Wadia setup you are loosing sound quality.
One of my biggest audio fears is that someday all audio files may be MP3.
I have ripped my entire CD collection in AIFF to my external hard via Firewire through my Mac Mini. Do I have the ability to load those music files on to an iPod and choose the format ie AIFF? I guess the issue is space, WAV files take up less space the AIFF.
Hard drive space is cheap. Get the touch with 32mb, that should hold at least 20-25 albums of wav files at a time.
Quote from: K Shep on 9 Oct 2009, 03:58 pmI have ripped my entire CD collection in AIFF to my external hard via Firewire through my Mac Mini. Do I have the ability to load those music files on to an iPod and choose the format ie AIFF? I guess the issue is space, WAV files take up less space the AIFF. Yes. If you want a different format than what is in your library, you will need to convert (make a second copy) in another format. If your library is AIFF and that's what you want on your iPod, you're good to go. I just compared a WAV file to an AIFF, and they were essentially the same size within a few KB, for a ~36MB file, the WAV file was only 3KB less, so it's a non-issue. Steve
