Good, thin 2 channel speakers?
0 Members and 1 Guest are viewing this topic. Read 5411 times.
opnly bafld
Re: Good, thin 2 channel speakers?
« Reply #20 on: 9 Oct 2009, 12:32 pm »
Some very good suggestions!
Were these mentioned?
http://www.epos-acoustics.com/products/m16i.php
Lin
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #21 on: 10 Oct 2009, 06:36 am »
Saburo ... but you'd need to a little diy.
6 5/8 x 18 x 71 3/4
http://homepage.mac.com/tlinespeakers/FH/download/Saburo-1v0-map-0102008.pdf
dave
bunky
« Reply #22 on: 10 Oct 2009, 10:01 am »
I am running a pair of Audio physic Spark IV floorstanders that are 6 7/8 " wide .in my opinion they are very fine looking and sounding two channel loudspeakers. these little gems retailed for $4000 + and I bought them used on Audiogon for under $2000. good luck....WCW III
twitch54
« Reply #23 on: 10 Nov 2009, 03:07 pm »
(After a second glance, the wooden thing in the middle is certainly NOT a speaker)  :roll:
it's that Synergistic Research 'sphere'...... ie. - room bass tuning eq device, I wasn't impressed, but then again when I walked into that room and saw those speakers I damn near lost my lunch....YUK !!
funkmonkey
« Reply #24 on: 10 Nov 2009, 06:31 pm »
I think the bigger Totems, i.e. the Sttaf and the Hawk fit the width criteria and should have a much bigger rock out factor.
You're right.
Staff = 6.3"W
Hawk = 6.8"W
Totem Hawks are quite nice, I almost bought a pair myself.  Surprising amount of sound and depth from a fairly small speaker.  You would could buy them used and save a bit, I've seen them for as low as $1400 on Agon... They also look nice.   :thumb:
