Sub Amp Components
0 Members and 1 Guest are viewing this topic. Read 1068 times.
ebag4
Sub Amp Components
« on: 30 Sep 2009, 01:10 pm »
I have a couple of subwoofer amps that have gone out.  A buddy has tracked down the bad components however we have not been able to locate replacments.  I have already run them through Occams' search engines stickied above (thanks Occam) to no avail.  The amps are surplus from Apex Jr, the Infinity OVTR 1 amps.  The parts I am looking for are:
SEC RIFS 250
TB2102
These are tranisitors.  I had a hit on the search engine for the TB2102 at American II, but there is no cutsheet available so I have not confirmed it is the correct component (different part number).  It won't do me any good if I can't find the SEC RIFS 250s I need.
Ed
Bob in St. Louis
Re: Sub Amp Components
« Reply #1 on: 30 Sep 2009, 04:50 pm »
Ed, I did a quick search on mouser.com with the first part number. There are several pages of results. However, you're over my head so I don't really now what I'm looking for. The second part number had no results.
Hope that helps 'ya buddy.
Bob
ebag4
« Reply #2 on: 30 Sep 2009, 04:59 pm »
Thanks Bob.  I have checked Mouser and all the usual suspects.  Occam has an excellent tool stickied at the top of the Lab forum, it has a few search engines that checks several vendors at a time, no luck.
I have an email into Harman Int-Infinity div.  I don't know if they will respond but it's worth a shot.
Thanks again,
Ed
