0 Members and 1 Guest are viewing this topic. Read 10240 times.
So, whadaya think? New? Old? Doesn't matter? Neither?
Even though each of us might have a different opinion and/or experience, but we are all here to stick our noses into your business help and support you.
IMO if you put some effort and heart into the man-cave you will use it as a listening room. Address room acoustics and build a nice system.
In a precious few years, my daughter is likely to start socializing with peers and won't have much interest hanging with us. Until then, I don't want to make a routine of going downstairs.
Perhaps, I can set the Salks up in the Master Bedroom. It is 14 X 20 with cathedral ceilings. Is their a strong preference as to whether the speakers face across the 14' or down the 20'?
Quote from: FidelitySeeker on 22 Sep 2009, 01:09 pmPerhaps, I can set the Salks up in the Master Bedroom. It is 14 X 20 with cathedral ceilings. Is their a strong preference as to whether the speakers face across the 14' or down the 20'?Should I take this question to another subject/thread or does it just not matter enough for anyone to have an answer?TIA
