Total Members Voted: 21
0 Members and 1 Guest are viewing this topic. Read 9564 times.
I use dual DIY TC2000 15" sealed subwoofers. The ST's are rated conservatively, and go lower than 42Hz. But a subwoofer fills in the bottom octave, and its a must for me.
Thank you all for your responses. I'm now experimenting with the subwoofer on 2 channel music. Also trying out Room EQ Wizard (REW) to measure room responses. If you don't know about this already, check out http://www.hometheatershack.com/forums/rew-forum/forum on Home Theater Shack.
My hats off to you for an extremely complete, thorough and detailed review of all the loudspeakers you auditioned prior to arriving at your current favourite. A very enjoyable read.Anand.
I have my SongTowers in a strictly 2 channel setup and have experimented with an older Energy 10? sub with generally disappointing results. The best use of this I have found is crossed over low (40Hz) with the SongTowers playing full range. Crossed over higher and it is painfully apparent that the sub cannot keep up with the SongTowers. I am sure a better sub would yield very different results.I have also worked with REW, great software. I was able to get a very flat frequency response with the sub, but unfortunately, that does not tell the whole story. The graph won?t show that the bass is slow and lacking in definition, that still takes ears. I guess all I am trying to say, if you are going to use a sub with the SongTowers, make sure it is a good one.
The Rythmik options are good. I personally like the Rythmik subs, so don't hesitate if you're leaning that way. Also, Jim now offers (through Rythmik) a dual passive subwoofer. I bet that will sound awesome!
Quote from: Nuance on 18 Aug 2009, 09:49 pmThe Rythmik options are good. I personally like the Rythmik subs, so don't hesitate if you're leaning that way. Also, Jim now offers (through Rythmik) a dual passive subwoofer. I bet that will sound awesome!Hi Nuance,Could you explain a bit more about this Salk option with Rythmik? I searched and couldn't find anything on the Rythmik website and Jim's website for the Song Sub doesn't mention Rythmik either.
