Poll
Do you use a subwoofer with your SongTowers?
Only for 2 channel
2 (9.5%)
Only for HT
4 (19%)
For everything
10 (47.6%)
Never
5 (23.8%)
Total Members Voted: 21
SongTowers with subwoofer?
0 Members and 1 Guest are viewing this topic. Read 9561 times.
Nuance
Re: SongTowers with subwoofer?
« Reply #20 on: 31 Aug 2009, 03:12 am »
Thank you all for the information and responses.
I did try out REW and learned my current SW response is pretty bad, there's a post on Home Theater Shack (http://www.hometheatershack.com/forums/rew-forum/20907-rew-novice-graph.html).  Also in my room, bringing the speakers more forward from the front wall can help.
I do want to upgrade the sub.
:(  Bummer man, that's tough.  If you had an EQ you could at least kick some notches in those peaks, but I think going with a new subwoofer will gain you so much more, and then some.  If you corner load a sealed sunbwoofer like a Rythmik you should be flat to 15Hz.
I hope everything works out for you.
oldmp3
« Reply #21 on: 31 Aug 2009, 05:22 pm »
Thanks, Nuance.  The Rythmik D15SE is on my wishlist.
