Okay, I'll just answer your questions and not go deeper into this. If it even looks like we are arguing then we are done. I had more questions for you but will withhold them.
Your ears are measuring it right?
I was referring to a microphone measurement.
They respond to stimuli and I'd say it is reasonable to say that if the stimuli is the same, in two different situations then the results should be the same.
If all else is equal then I agree. But is all else equal (not really meant as a question, just a provoking thought)? We were only talking about amplitude in all directions. If all else were the same then they would be the same speaker.
It would take more than frequency response measurement to fully characterize it but at the end of the day, our ears are a pair of microphones connected to a signal processing device. They either measure the stimuli and process it or they don't. The how is the interesting part.
Ah, I agree. And aren't our ears more than a device that measures amplitude (again, not really asking a question)? I can play a 1kHz note on a piano and a 1kHz note on a flute to the same amplitude, but they do not sound the same. And yes, the how is a very interesting part.
In terms of stored energy, waterfall plots are almost useless (Toole & Olive 1988, Olive 1994). They don't tell you enough about the character of the resonances to be tied to what is and is not audible.
That is a very subjective statement and I do not agree with it. CSD are highly under rated.
It is the exact opposite of a subjective statement. It is one that is based upon objective data and that is why I made it. It isn't my opinion. It is based upon the research of the audibility of various resonances.
I think anytime anyone says what is not audible then it is subjective. You might as well say "I" didn't hear a difference, and "I" don't think anyone will hear a difference. Or "I" don't hear a difference in "my" test, with "my" system.....
There are subjective differences even if we just look at hearing ability alone. When I had a group of the high school kids over we did some listening experiments. We humans are only "supposed" to only hear from 20Hz to 20kHz. But I had two girls here that could hear 22kHz immediately and repeatedly. The rest of the class could not.
