NuForce Icon as mono amp?
0 Members and 1 Guest are viewing this topic. Read 1168 times.
LFord
« on: 27 Jul 2009, 03:03 pm »
I'm wondering if the Icon could be used as a mono amp.  If you brought a mono signal into both the RCAs via a Y-cable and tied the speaker outputs together, would this pseudo-bridge work?  I'm assuming a nominal 8-ohm speaker.
Lou
nuforce-casey
Re: NuForce Icon as mono amp?
« Reply #1 on: 29 Jul 2009, 05:36 pm »
Unfortunately, this will not work, you'll destroy the Icon's output stage right away.
LFord
« Reply #2 on: 29 Jul 2009, 07:19 pm »
Ah, then we won't do that.  :nono:
What about running just one channel?  Does it get upset if there's not a load on one channel?
Lou
