SOLD - Van Alstine Omega II 170 Power Amp - $150
0 Members and 1 Guest are viewing this topic. Read 2224 times.
xecluded
« on: 24 Jul 2009, 06:16 pm »
For sale is a Van Alstine Omega II 170 Power Amp.
Amp is not working. Blew fuses.
It's old, dusty and rusty.
It sounds really nice when it was working many moons ago; put it away when it died.
If you can fix it - good, if not, can't help you as I have no idea how.
Needless to say it is sold as is.
$150
« Last Edit: 25 Jul 2009, 09:03 pm by xecluded »
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
Re: Van Alstine Omega II 170 Power Amp - $150
« Reply #1 on: 24 Jul 2009, 06:30 pm »
You should be able to get it rebuilt by AVA, into a current model Insight 170 for a little over $400:  http://www.avahifi.com/root/ordering_info/AVA_PRICES_1108.pdf
Call AVA for info
xecluded
« Reply #2 on: 24 Jul 2009, 07:40 pm »
I am into low watt single ended tube amp now. Thanks.
avahifi
    • http://www.avahifi.com
« Reply #3 on: 24 Jul 2009, 08:03 pm »
This amp is certainly repairable.  Did you try replacing all five fuses at once (four internal 3 amp quick blow, one external 4 amp slow blow)?
Often users overlook blown fuses mounted on the fuse clips on the audio boards, and replace only one of a blown pair.  This causes the fuse to blow quickly again.  The amp is VERY rugged and nearly always a blown fuse is all that is wrong with it.
Frank Van Alstine
xecluded
« Reply #4 on: 24 Jul 2009, 09:09 pm »
I may have to try that.  Will go to Radio Shack and get the fuses. I will post the update.  If it works I would just keep it for spare.  Many thanks for the tip Mr. Van Alstine.
rlee8394
« Reply #5 on: 24 Jul 2009, 10:30 pm »
Tone Depth,
The upgrade is $699 for that circuit in the ST-120 chassis. Don't know why that chassis would be any more expensive than the others though.
Ron
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
« Reply #6 on: 24 Jul 2009, 11:23 pm »
Tone Depth,
Ron
Ron,
You are so correct, I must have picked off the AVA chassis, rather than the Dyna chassis from the cost sheet.  Thanks for your clarification!
rlee8394
Re: SOLD - Van Alstine Omega II 170 Power Amp - $150
« Reply #7 on: 26 Jul 2009, 10:47 pm »
Tone,
I bought it anyway. Curious to see what the problem is. I'll keep you posted on what I find.
Ron
rlee8394
« Reply #8 on: 6 Aug 2009, 04:10 am »
I transplanted the amp to a cleaner chassis. When powered up, the B+ fuse for the left channel blew. Measured a dead short from the B+ line to ground. Culprit was a shorted reverse biased 1N4007 diode between the B+ line and ground. Replaced diode, put it all back together, and have been listening now for a half hour!
Ron
JerryM
  • Where's The Bar?
« Reply #9 on: 6 Aug 2009, 04:20 am »
Ron
Sweet!!!  :thumb::beer:
Art_Chicago
« Reply #10 on: 6 Aug 2009, 08:18 pm »
Ron
So now you need to sell it!
Wayner
« Reply #11 on: 6 Aug 2009, 08:44 pm »
I have the 170Insight in the most mint Stereo 120 cabinet! It is very sweet sounding amplfier with plenty of muscle for a nice small package.
Wayner  aa
