Incorporating W frame into furniture
0 Members and 1 Guest are viewing this topic. Read 2884 times.
dvenardos
« on: 18 Jul 2009, 12:10 am »
My next speaker project is going to be the GR  Research OB subwoofer:
http://www.gr-research.com/pdf/obsub.pdf
Would it cause any problems to take the W frame and add storage shelving on the top or bottom in order to make it also functional furniture and blend into the room better?
Don
454Casull
Re: Incorporating W frame into furniture
« Reply #1 on: 18 Jul 2009, 04:17 am »
No problems that I can see.
mightym
« Reply #2 on: 19 Jul 2009, 06:10 pm »
Aren't you going to want those away from the wall?
John
dvenardos
« Reply #3 on: 20 Jul 2009, 07:49 am »
Yes, but where I have in mind for it I don't want it to look like a speaker just sitting there.
JohnR
« Reply #4 on: 20 Jul 2009, 10:56 am »
If you want to minimize vibrations, I wonder if you may want to consider the Linkwitz-style W baffle - in which the drivers move push-pull, in the arrangement shown there is still a force component that doesn't cancel.
Even so, I don't know how well that would work for your planned use - you may have to build them and try them. Perhaps consider decoupling the sub cabinet from the furniture around it? I think I saw someone do something like that here recently.
mcgsxr
« Reply #5 on: 20 Jul 2009, 06:13 pm »
I cannot think of any reason that an OB sub could not be incorporated into a coffee table, so long as you don't mind a woofer basket hanging out of the middle of it!
I used to put an Ikea LACK table over the top of this, and it masked the ugliness some...
dvenardos
« Reply #6 on: 20 Jul 2009, 06:19 pm »
Thanks guys, we will see how it goes.  :thumb:
Rudolf
« Reply #7 on: 21 Jul 2009, 08:24 am »
Not a problem, just a consideration:
A dipole woofer will excite vertical room modes least when standing on the floor. If you raise it up considerably, you may choose 1/5 or 1/3 of the room height to get the most homogeneous distribution of the vertical modes.
Rudolf
