0 Members and 1 Guest are viewing this topic. Read 7850 times.
Leaving tube gear is actually good for reliability but wears out the tubes from dissipation. Trade off and most think that the tube wear is worse for a well designed amp that turns on and off gracefully.I turn mine off as it generates heat even though its only a 10+ watt single ended amp.
Yeah electrical costs and wear on the tubes makes it not a good idea for tube amps. Preamp might be different but depends on the design. When you switch on/off an amp it creates a sudden in rush of current. Tube rectifiers really do a lot to negate this because they warm up slowly (most) so the tubes have had time to heat their heaters/filaments before getting slammed with high voltage. Also, tube rectifiers usually have a ramp up as rectifier warms up so the high voltage isn't all or nothing. Solid state diodes(rectifiers) will conduct immediately and if your caps are large and/or there is little inductance/resistance leading the supply filter you will get a heavy current inrush. That can be hard on your caps, your transformers, tubes, etc. There are ways to design (thermistors, delay relay switches, manual delayed switches, choke input supplies, etc) so this is not an issue even with solid state diodes but that costs money, so it isn't always done right.
Quote from: JoshK on 8 Jul 2009, 01:43 amLeaving tube gear is actually good for reliability but wears out the tubes from dissipation. Trade off and most think that the tube wear is worse for a well designed amp that turns on and off gracefully.I turn mine off as it generates heat even though its only a 10+ watt single ended amp.Josh,In what way is leaving tube gear on good for reliability? I hear this from time to time, but have never heard why it is so? I have asked various amp vendors (tube and ss) and the overwhelming majority have said to turn off the gear when not in use vs. leave it on.I know the Mythbusters proved leaving your lights on wasn't the correct approach and that one was better off (from a cost and longevity perspective) constantly turning their lights on/off rather than leaving them on for long stretches. George
That is a little different in broadcasting though. They typically operate in extremely high voltage and there catastrophic failure isn't rare because of the voltage. For consumer gear in the 400-600V B+ range its a lot less of a problem, but still can be a problem in cheap chinese gear or shotty designs.
Back in the day when tubes were still used in broadcasting it was standard practice to leave all gear powered on to prevent calibration drifting and to avoid failure on power-up, where at least anecdotally most tubes catastrophically fail as opposed to just wearing out over time.
I'm doing the same Bob with my Mantissa as well My tubed cdp however is on standby continuously and is never turned off -sounds better that way
Quote from: bluemike on 8 Jul 2009, 02:18 pmI'm doing the same Bob with my Mantissa as well My tubed cdp however is on standby continuously and is never turned off -sounds better that way Hey - did you see the Mantissa for sale on Audiogon? Someone is sure going to get a rare deal on that.
