0 Members and 1 Guest are viewing this topic. Read 35139 times.
...I have no doubts that these fancy outboard supplies are better than the supplied wall wart. However, that will not affect the jitter that is generated by the poor supply that feeds the clock and SPDIF output chip. And that is what will really make a difference.If the guys that make these outboard supplies were as clever as they like to imagine that they are, they would find a way to make one that provides for a clean supply dedicated to that part of the SB2/3. But, that would involve modifying the guts of one. Not as easy as making some over-priced accessory that anyone can plug into the power connector....
Quote from: art on 21 Dec 2007, 08:42 pmI have no doubts that these fancy outboard supplies are better than the supplied wall wart. However, that will not affect the jitter that is generated by the poor supply that feeds the clock and SPDIF output chip. And that is what will really make a difference.Yep Pat. It seems rather silly to spend more on a power supply when simply disconnecting the clock and clocking it externally, as the pacecar does, yields a much better result at a cheaper price. Although I may eventually get a pacecar, because I don't know of other similar products, I think Steve's solution could be done cheaper. http://home.socal.rr.com/audio_gestalt/default.htmIf you, or someone, could create such a device at a reasonable price (say below Aus $500) then you would have at least one customer (me). Some people claim they can hear jitter of 2ps. I would like that claim put to a blind listening test some day. Burson audio has a clock with jitter about 5-10 ps - maybe a bit higher. They claim never to have found anyone that can detect that level of jitter.Of course that is using an external DAC. The claim is with these power supplies, and mods, the internal DAC sounds 'fantastic', beating things like a Wadia (not that I am a fan of Wadia mind - but that is another story). I have a lot of respect for some of the people making that claim, but believe a well designed external DAC being fed a low jitter signal will outperform it. ThanksBill
Paul:I am not trying to knock the "competition" (they really aren't competition, since we are not in the business of doing those sorts of product mods. ) I am merely pointing out that it make little sense to stick on an expensive outboard supply, and ignore a key problem. Seems to me that at least one of those guys would have thought of that already.Don't know much about SN's stuff. I get the idea he has an external clock that you pump into the unit. Yes, that is one way to solve the problem. Still, the chip that does the clock also does the SPDIF output. (I believe more than one of us has pointed out that the 48 kHz clock can be disabled.)If you only have one internal supply, (and a SMPS at that) to power the big FPGA and all of that stuff, it is going to be hard to completely isolate the noise it places on the rail from the critical chips. The problem arises since the PSRR of CMOS gate is only 6 dB at the midpoint. Which is around the point when the logic levels are changing states. Not the right time to have things wandering around, due to noise on the rails.As for how much jitter you can hear??????Well, I dunno. I would not say that one can actually "hear" the jitter. More like one can better detect lack of jitter. Jitter has to be quantified as to both magnitude and frequency spectrum. To say "It is 20 pSec", without having the spectral content known, is not really helpful.But, back to your question:A lot of folks that I work with claim that when you get jitter measurements down into the single digits (pSec-wise), you can not detect much of a change.It also depends if the jitter is Gaussian or data-dependent. The latter being more discernable, in a negative sense.Jitter is much less of a problem in CD players. The main way data-dependent jitter is introduced is when they use the filter chip to generate the clock. SPDIF is a different animal. Tons of data-dependent jitter.
Wait a minute - how come I got jumped on but Jim didn't?
A few semi random thoughts... QuoteIf you are going to a DAC, there should be absolutely no difference. The bitstream either puts out should be EXACTLY the same as the original CD. In this case, the DAC determines the sound quality.The bit stream should be the same, but that is not always the case. The redbook CD standard includes an error correction mechanism to try to fill in any missing bits whe a disk it not properly read. How often this kicks in will depend on the quality of the disk and the quality of the player. One of the advantages of a hard disk based system is that since the disk does not have to be read in real time, it can be re-read to verify the bit were read correctly. There are a few, very expensive, transports that do this but they are not the norm. The new, hideously expensive, Boulder that is in this months Stereophile is one such device. I believe the PS Audio Perfect Wave Transport does this as well.Even if the data is exactly the same, there are unfortunately other things that can cause trouble. The obvious one is jitter, which are timing errors. Modern DAC's are much less sensitive to this but it can still be a problem. Bits are still the same but not necessary decoded at precisely the correct time. Another thing that can muck it up is the integrity of the waveform. It should be a perfect square wave, fully on or fully off. But things can cause trouble and lead to potential errors. Noise in the supply rails can raise the zero level, the leading edge can become slightly rounded, ringing can occur. These can make it more difficult for the DAC to decode the signal and can impact the timing in the case of a rounded leading edge. There is a excellent thread on digital signals by Pat from Analog Research Technology with a heading something like "improving the Squeezebox digital output". He is an RF engineer and has posted TDR traces showing what a digital output should and should not look like. IMO it's well worth the time to find and read, regardless whether one owns a squeezebox or not.As to the efficacy of a power supply on the squeezbox. Some years ago when I first started playing with them I built a solid linear supply and a battery powered supply. Both used the same regulators and similar filter caps. I fitted a toggle switch in the box and there is sufficient capacitance in the SB to allow real time switching with no noise or dropout. Since they were both regulated at 5V there was no change in level, so it was a fair comparison. At a get together I asked for feedback from the folks present. While not double blind, it was single blind in that I was the only one who knew what supply was in use. All participants could tell them apart and much to our surprise the AC powered supply was preferred. I'm sure this isn't definitive enough for many folks but it was quite clarifying for me. Just my nickels worth, YMMV. mike
Quote from: jsalk on 8 Jul 2009, 04:17 am But I still can't understand why when using the SB's digital outputs it could make any difference.- JimThat's what I've been wondering this entire time, thus my disbelief in them. Wait a minute - how come I got jumped on but Jim didn't?
Quote from: zybar on 7 Jul 2009, 10:37 pmJim, I have asked a friend who is much more technical than myself to respond to your questions. If he doesn't I will give it a crack. BTW, not last year, but the year before, there were quite a few people in the David Ellis room who got to hear SB power supplies from Wayne at Bolder Cable and Hugh at AKSA Audio and all agreed that they heard improvements over the stock PS. GeorgeThe power supply I used at RMAF was supplied by one of the two you mention. I can definitely see the benefits if you were listening to the analog outputs (and I imagine most of those hearing the difference were). But I still can't understand why when using the SB's digital outputs it could make any difference.- Jim
Anyone here use a squeezebox with a Mac or PC? If I'm not mistaken, you install a program on your computer and it simply streams from your computer, it doesn't actually hold the files itself. If I'm not mistaken, someone said Jim demos hooked up to a squeezebox, but I have to wonder if he brings a computer along or has some nifty setup.I'm trying to figure out the best way to get my songs across the room into an Insight preamp. Can you run a squeezebox off of iTunes or do you have to use their separate music server?
Jim,I hope Mike's post and the link I provided to Pat's thread shed some light on why there are differences in transports and how they can produce a different sound through the same DAC.As always, in the end, it is perfectly ok that with disagree and have differing opinions.George
Nuance,Because Jim didn't attack and slander other vendors here at AC like you did.You can't make the statements like you did about two of our more well respected vendors (without even hearing, testing, and measuring their products) and expect to not be challenged. George
Jim,Maybe I am a little dense this morning (or every morning), but in the test you mentioned in your post, it is unclear to me what you exactly tested? Did you have a transport or cd player with the physical media in it connected to the same DAC as your SB? If so, what was the transport or physical cd player?Are you saying that using the same DAC that there was no difference in sound between the transport or cd player using physical media and the SB using ripped media (same exact cd) off the computer?George
So Jim, was one an optical and one an SPDIF? If so, that may be apples and oranges for the more technically savvy.
I would be very interested if anyone has any findings on whether there is a difference using a CD Transport or Duet or Transporter to feed signals to a high quality external dac.
Clearly I am in the camp that feels a computer can offer superior transport abilities when feeding an external DAC (which can include a Duet, Transporter, USB DAC's, etc...).George
Quote from: mr_bill on 8 Jul 2009, 04:40 pmI would be very interested if anyone has any findings on whether there is a difference using a CD Transport or Duet or Transporter to feed signals to a high quality external dac.Pretty much the same answer. I found that the SB feed was more "clean", or as they say, had a blacker background to it. Subtle but enough over time I actually sold my CDP and went sans any mechanical drive.
Quote from: Big Red Machine on 8 Jul 2009, 06:10 pmQuote from: mr_bill on 8 Jul 2009, 04:40 pmI would be very interested if anyone has any findings on whether there is a difference using a CD Transport or Duet or Transporter to feed signals to a high quality external dac.Pretty much the same answer. I found that the SB feed was more "clean", or as they say, had a blacker background to it. Subtle but enough over time I actually sold my CDP and went sans any mechanical drive.Interesting..... I have the opposite experience. When I bought my Duet, I was dissapointed in its sound quality. I ran it through the same DAC that my transport was connected to, and the Duet was NOT as good as the transport. I kept using the Duet because I liked so much about it, but eventually quit because I couldn't stand the sound. If you guys are able to get a "clean" digital feed out of one, then maybe I am doing something wrong. Any suggestions?Thanks
