0 Members and 1 Guest are viewing this topic. Read 35186 times.
Quote from: Kris on 7 Jul 2009, 11:38 pmAnyone claiming he can hear" dramatic differences" is implying the rest of us are not good listeners, or we are deaf.The only dramatic differences i can hear is when changing speakers or rooms. Everything else is subtle.No, those are not the implications.. Likely that the system is not as resolving. I wish some changes (like changing power cords, for goodness sake) weren't dramatic...but they are. Dan's mods are dramatic. Wayne's mods are dramatic. A new DAC like the Weiss is dramatic. Room treatments are dramatic. Some cables are dramatic (in many cases lately, dramatically worse). not saying that some changes aren't subtle...but had to pipe in and state that many posters here are quite legitimate in their declarations that these recipes in computer audio are still being worked on, and in many cases cause a dramatic change in sonics..sometimes where we least expect it. Keep an open mind...and ear. We aren't calling you deaf.
BTW, not last year, but the year before, there were quite a few people in the David Ellis room who got to hear SB power supplies from Wayne at Bolder Cable and Hugh at AKSA Audio and all agreed that they heard improvements over the stock PS. George
Henry,When you come over, we can do a test with my SB I use in the HT system. I have the stock wall wart and an elpac PS modified by Wayne at Bolder Cable. We can send the digital out of the SB into the Modwright TP and listen to it with both ways. Putting aside which is preferred, I am confident you will hear a difference.George
Well, FWIW, I've had my Duet for little over a year now. I was one of the first to purchase a linear power supply for it when Wayne at Bolder made them available specifically for the Duet. After having it in my system for about a month, I noticed a dramatic increase in how the bass sounded. The bass was more "full" overall, but the biggest difference was how the bass tightened right up. It was a definite improvement. There was also in improvement in how quiet the background was compared to the standard power supply. I eventually purchased an AVA Insight DAC. With the DAC the soundstage was broader, giving the instruments a more "3-D" like effect. I did have the op-amps upgraded just a few months ago and couldn't hear a difference between the new ones and the old ones.I eventually sold the DAC and will be getting my Duet modded by Wayne. Having prior experience with Bolder products and doing a little research on Wayne's mods makes me comfortable that my Duet should give me the sound I'm looking for, above and beyond what I experienced with my external DAC.I just wanted to shine a little light on the subject from someone who has first-hand experience at both ends, instead of spewing forth my opinion without any solid ground to stand on."A scam to get you to spend money", c'mon, you're better than that.Doug
Dan's work is proof positive. Dramatic isn't a good enough adjective.
Gear, cables, treatments make audible differences. In a highly resolving system these differences are noticeable and distinct. The only thing that always sounds the same is the people who say they make no difference
ironic that gear is so subtle that after hearing a very low level 2 channel pre-amp you bought one
Nuance,There is no universal truth that double blind tests are the way to prove or disprove anything in audio. If you want to hang your hat on that, no issues - that is certainly cool.But please don't act as if it is the end all, be all, and if anybody views differently it is the equivalent to somebody claiming the world is flat and not round.George
Quote from: rydenfan on 8 Jul 2009, 01:14 amironic that gear is so subtle that after hearing a very low level 2 channel pre-amp you bought one That's a pretty low blow. We aren't all rich or have the extra income to blow on expensive gear. And that's the ONLY thing that kept me from spending more. I would have expected a more civil response from you, especially considering how offended you get when people use the same tone with you over at AVS forum. I guess I misjudged you.
As I you...Maybe you should g go back and re-read the content and tone of your posts that lead us to this point?George
Quote from: ted_bDan's work is proof positive. Dramatic isn't a good enough adjective. Ah...I am pretty sure his work is not proof positive. If it was, where's the proof?
Nuance, you took my comment COMPLETELY wrong! and I apologize if that is how it came off. my point was that gear is not subtle and you were able to discern it on a piece that does not cost a fortune. Nothing more than that. I was merely making the point that clearly you believe gear does make a difference or you would not have spent your hard earned money on it. Again my apologies if you read it differently. i was only trying to make the point that you hear differences yet were jumping on others for feeling that way so I was confused.
Quote from: Nuance on 8 Jul 2009, 01:04 amQuote from: ted_bDan's work is proof positive. Dramatic isn't a good enough adjective. Ah...I am pretty sure his work is not proof positive. If it was, where's the proof? Nuance,?? Dan's proof is in all his great reviews, awards and most importantly, many sales and happy customers (esp us tube rollers). I'm sure you aren't kidding with this response, but surprised you hadn't done your homework.
Quote from: rydenfan on 8 Jul 2009, 01:26 amNuance, you took my comment COMPLETELY wrong! and I apologize if that is how it came off. my point was that gear is not subtle and you were able to discern it on a piece that does not cost a fortune. Nothing more than that. I was merely making the point that clearly you believe gear does make a difference or you would not have spent your hard earned money on it. Again my apologies if you read it differently. i was only trying to make the point that you hear differences yet were jumping on others for feeling that way so I was confused.Oh, sorry man. Gotcha. That's good to know dude, cause for a while there I was pretty bummed. My apologies. I am getting gang raped here, so I thought you had just joined in.
Quote from: ted_b on 8 Jul 2009, 01:27 amQuote from: Nuance on 8 Jul 2009, 01:04 amQuote from: ted_bDan's work is proof positive. Dramatic isn't a good enough adjective. Ah...I am pretty sure his work is not proof positive. If it was, where's the proof? Nuance,?? Dan's proof is in all his great reviews, awards and most importantly, many sales and happy customers (esp us tube rollers). I'm sure you aren't kidding with this response, but surprised you hadn't done your homework. Perhaps I was too quick to lump Dan's work in with the rest of the voodoo and snake oil scams out there. I recant my statement about him. If I ever try one of his power supplies, then I'll re-post. I honestly don't think the difference will be worth the cost, but that's highly opinionated and YMMV. I have done my homework, by the way, but it's strictly been the research kind.Previous posts edited.
Dan's happy customers and his great work don't need the Nuance stamp of approval. His proof is widespread....researched or otherwise.
