BP/20 MPS-1 Problem!!!
0 Members and 1 Guest are viewing this topic. Read 4024 times.
danman
« on: 5 Jul 2009, 02:32 pm »
Went to turn on my pre just now and it just stays red!!!!!!!!!!! Worked fine last night.
Unplugged everything and checked but nothing!
danman
Re: BP/20 MPS-1 Problem!!!
« Reply #1 on: 5 Jul 2009, 02:39 pm »
Well..............the unit is dead!!!!!!!!!! I have no idea what is going on! :cry:
Robert D
« Reply #2 on: 5 Jul 2009, 02:44 pm »
danman, MPS-1 IS LITE UP !
maybe a Cable ?
Robert
danman
« Reply #3 on: 5 Jul 2009, 02:45 pm »
Both are red!
Changed cables and still red!
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 5 Jul 2009, 02:49 pm »
HI Dan,
May be a fuse - I will check with Mike for you.
james
Robert D
« Reply #5 on: 5 Jul 2009, 02:50 pm »
Your Amp's are Lite ? Green ????
Just the Pre Amp Dead
danman, Try a New Circuit (ac outlet)
Maybe you Blew a fuse
Robert
danman
« Reply #6 on: 5 Jul 2009, 02:56 pm »
I changed outlets and still red! Am I able to check the fuse myself?
« Reply #7 on: 5 Jul 2009, 03:02 pm »
Hi Dan,
Hang to until Mike gets back to you as he is far more knowledgable on the preamp than I.
james
danman
« Reply #8 on: 5 Jul 2009, 03:06 pm »
No problem............I will just have to bite my nails and see my shrink since I will now go without audio for a day AAAAGGGHHHHH!
It is probably something stupid anyways!
« Reply #9 on: 5 Jul 2009, 03:21 pm »
Dan,
I assume you do not have the MUTE switch on?
james
danman
« Reply #10 on: 5 Jul 2009, 03:26 pm »
Nope! Checked that as well.
Laundrew
« Reply #11 on: 5 Jul 2009, 03:44 pm »
Audio withdrawal... the headaches will most likely begin this evening  :slap:
danman
« Reply #12 on: 5 Jul 2009, 03:45 pm »
O.K.................For some reason it just came back on!!!!!!!!!!!!
Maybe it went into some reset mode!!!
Working now but I did nothing!!! Very weird! But I am happy! Any ideas?
« Reply #13 on: 5 Jul 2009, 04:12 pm »
Only explanation I can offer is bad booze!
james
« Reply #14 on: 5 Jul 2009, 04:17 pm »
It could be very low voltage.
I have found the power system we all have is just getting worse and worse with all these computers, florescent lights and switching power supplies coming on line.
james
danman
« Reply #15 on: 5 Jul 2009, 05:06 pm »
That is possible however my amp and CD did not have a problem coming on. I am using a 20 amp seperate breaker but who knows!?
I will keep an eye on it to see if it happens again and get back to you.
Thanks everybody.
werd
« Reply #16 on: 5 Jul 2009, 07:22 pm »
Its cuz you are using Bryston/ML combo  :duh: dont you get it they dont work togther .... gawd!!!!!
 :lol:
Robert D
« Reply #17 on: 5 Jul 2009, 07:44 pm »
I'm sure you have a Power Problem some where.
What other problems do you have ?
Just the BP20 & MPS-1 ?????
To much load on the breaker Unplug the Toaster !
Robert
danman
« Reply #18 on: 6 Jul 2009, 12:04 am »
Everything else was working fine except the pre. Like I said I have a dedicated 20 amp curcuit and regulator and I will give great credit to Hydro-Quebec as they do have one of the best sytems (supposedly!).
I turned it off this p.m. and just turned it on now and it worked as usual no problem! Strange but who knows? I will keep my eyes open for anything else unusual! I personally don't believe the unit itself has a problem so I am not worried and even if there is some sort of gremlin, I am still not worried as I will just pack it up and send it that is the advantage of Bryston!
Mad Mr H
« Reply #19 on: 6 Jul 2009, 08:43 am »
Hi,
I did not want to post as I had this EXACT same issue from time to time.
BP20 or BP25 with MPS1.
And just like you say - did nothing and it comes back on !!!
Im glad to hear this happened without my mention of the same thing.
Adds weight to what I found without pushing you in that direction.
I also remember that IF it was in mute it would be orange LED not red.
I dont have a BP20 or 25 at the mo.
