BP/20 MPS-1 Problem!!!
0 Members and 1 Guest are viewing this topic. Read 4041 times.
Mad Mr H
Re: BP/20 MPS-1 Problem!!!
« Reply #20 on: 6 Jul 2009, 08:47 am »
 :duh: :duh: :duh:
Sticking relay !!!
Why did I not think of that at the time I had mine............ :oops:
IF it is that it should NOT be considered an "issue" or "fault". If it happens all the time then its a fault.......
danman
« Reply #21 on: 6 Jul 2009, 06:10 pm »
Has not happened again since yesterday so I believe or hope it is a one off!
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #22 on: 7 Jul 2009, 01:49 pm »
HI Dan,
Mikes input:
In that case, the BP25 was probably just not coming out of mute automatically.  It doesn't say -did Dan try to manually un-mute it.  The light on the MPS1 will be red if the pre is muted.
Mike
danman
« Reply #23 on: 7 Jul 2009, 07:45 pm »
Actually, I  never touched anything it just came on, stayed on for about a half hour and then turned green! Both the MPS-1 and the BP-20 were red.
Thanks James. Everything seems to be working fine at this present time and I am not worried about it. If it happens again, I will let you know. Thanks.
dubkarma
  • "God made man because he loves stories." - Canetti
« Reply #24 on: 12 Jul 2009, 04:33 pm »
I had (what sounds like) a similar problem with a BP-25. For awhile it was intermittent: sometimes it wouldn't come out of mute and sometimes it would; eventually it wouldn't come out of mute at all. Sent it in to Bryston, mute switch was replaced; no problems since then.
danman
« Reply #25 on: 12 Jul 2009, 04:55 pm »
Only did it the one time so far! If it does it again I will keep what you mentioned in mind. Thanks!
