Super 70i on the way to Frank for Ultimate 70 upgrade
0 Members and 1 Guest are viewing this topic. Read 1364 times.
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
After reading the recent threads about the Ultimate 70, I sent my Super 70i to Frank yesterday for an Ultimate 70 upgrade.  The Super 70i has some good qualities, but the bass isn't very good, and I listen to the Insight 440 almost exclusively.
I have Salk HT2-TL speakers, which are easy to drive.  Although the Insight 440 produces 220 watts (more, I suppose, into the HT2-TLs' 4 ohm load) per channel, and the U70 produces 30 watts per channel, I have a small room, and I don't need to crank up the volume very high to listen to fairly loud music.  Regardless, I am looking forward to having a better tube amp.
Lefty052347
  • AVA Associate
Re: Super 70i on the way to Frank for Ultimate 70 upgrade
« Reply #1 on: 3 Jul 2009, 10:33 pm »
We listen to Frank's HT3's driven by a single Ulta Valve amp on a regular basis.  The Ultra Valve does just fine.  I believe you will be more than happy with your upgrade.
The Ultra Valve has the same circuits as the U70 but in a re-designed chassis.
Dean
hotroady
« Reply #2 on: 4 Jul 2009, 04:54 am »
I'm very glad to have gotten to mine last year! Was a little disappointed with somewhat flabby bass before circuit change. With update its much more solid bass. You might consider going to a larger power transformer, that's what Frank uses on the UltraValve. 5 more watts may come in handy, sometime. Ask Frank if you can hook you up.
