Audio/Video Gear and Systems
The Apple Core
Crimson
I want compression
I want compression
0 Members and 1 Guest are viewing this topic. Read 1424 times.
GDeering
I want compression
30 Jun 2009, 07:36 pm »
I never thought I'd ask, but I'm doing a lot of traveling and I can't play my uncompressed ituned iPod in the car. The problem is that the dynamics of classical music is beaten by the roar of the road. Radio compression makes listening to music much easier. Is it possible to dial in that sort of compression in iTunes?
Gregg
launche
...on being an audiophile...no.
Re: I want compression
30 Jun 2009, 07:42 pm »
Sounds like you might need some dynamat treatment and some different tires.
Isn't there a feature in most players or rippers for volume leveling?
bunnyma357
RetroGrouch
Reply #2 on:
30 Jun 2009, 08:12 pm »
From what I can tell, if you're on a PC the best way to do it is create another library with the Compression applied using Foobar and VLevel plug-in.
http://www.hydrogenaudio.org/forums/index.php?showtopic=71814
There doesn't seem to be a way to do it on the fly with an iPod or mp3 player, that I was able to find in my brief search.
I have the same issues, since I have a convertible, and just have gotten use to keeping my thumb on the steering wheel volume control.
Jim C
srb
Reply #3 on:
30 Jun 2009, 11:11 pm »
I went to look at my iPod to check the setting, but the battery just went dead!
It is called
Sound Check
under Settings, and provides some measure (not adjustable. it is either on or off) of compression/limiting.
Last Edit: 1 Jul 2009, 04:33 am by srb
The Apple Core
Crimson
I want compression
