Audio/Video Gear and Systems
The Apple Core
Crimson
Help Please With My New DAC
0 Members and 1 Guest are viewing this topic. Read 1694 times.
Atlplasma
Just off the boat
28 Jun 2009, 05:13 pm »
I'm hoping someone can point me in the right direction on this one.
I bought a Gigawork 24/192 upsampling DAC off ebay from a vendor in Hong Kong. My goal is to convert my first generation Mac Mini into a music server.
I hooked the unit up to the Mini via USB and ran an RCA connection to my Yamaha integrated. No output.
I checked the Sound setting in System Preferences and everything seemed okay (USB codec is visibile and USB out seems to be selected). But still no sound.
I tried making the connection over Optical but no dice.
I removed the USB upsampling card and set the jumpers to not upsample and tried the connections again. Still no sound. (The Mini internal speaker does play though.)
I changed over to my Powerbook and tried again. Same results.
Suggestions?
jtwrace
Re: Help Please With My New DAC
28 Jun 2009, 05:15 pm »
make sure the settings are correct like you first did and restart the computer. I've found that the computer doesn't like when I unplug the USB cable then plug it back in. When I restart, it's fine.
Worth a try
Rashiki
Reply #2 on:
28 Jun 2009, 05:21 pm »
You need to go to the "Audio MIDI Setup" app under Applications/Utilities and select the DAC as your default output.
-Rob
jtwrace
Reply #3 on:
28 Jun 2009, 05:24 pm »
this should help:
http://usbdacs.com/Macintosh/Macintosh.html
Atlplasma
Just off the boat
Reply #4 on:
28 Jun 2009, 05:51 pm »
I went to the Midi utility and now have music.
Thanks for the quick (and effective) replies.
Currawong
Newbie
Reply #5 on:
3 Jul 2009, 12:28 pm »
I recommend if you're going to switch the Audio Midi settings much, to get the SoundSource menu bar extra.
The Apple Core
Crimson
