FS: Four Channel Dual-Mono LM3886 Gainclone
0 Members and 1 Guest are viewing this topic. Read 1757 times.
gitarretyp
« on: 21 Jun 2009, 09:33 pm »
I built this amp originally as two channels and added the second pair to use in an active system. The boards and parts were purchased from chipamp.com. The case is a black anodized model from Par-Metal. One pair of the modules has upgrades parts including: Blackgate caps and PRP and Mills resistors. The amp is thoroughly over-engineered with two 330VA 24V Antek transformers (good for ~60W/channel) and far more heatsinking than necessary. Also, there is a soft-start module installed to avoid dangerous power surges at turn on. Input RCAs are Cardas, binding posts are Eichmann and Neutrik Speakon.
Since this started as a two channel amp and morphed into four, only one pair of the boards is accessible via conventional binding posts. To access all four channels, the 4-pole speakon connector must be used. As such, I will supply the mating Speakon connector for you to build your own speaker cables. Alternately, I will install another set of binding posts at cost upon request.
The case work isn't the best, and the case started-out as home for a GB150 amp (the reason for the hefty heatsinks); however, I think it looks pretty good with the top on and the blue LEDs glowing. Asking $300 $250 OBO.
« Last Edit: 12 Jul 2009, 05:19 pm by gitarretyp »
gitarretyp
Re: FS: Four Channel Dual-Mono LM3886 Gainclone
« Reply #1 on: 28 Jun 2009, 07:48 am »
Bump
gitarretyp
« Reply #2 on: 5 Jul 2009, 04:36 pm »
Bump
gitarretyp
« Reply #3 on: 12 Jul 2009, 05:22 pm »
Reduced a bit more.
Aside from being used in an active system, this amp could also be: used to bi-amp regular speakers or in a surround system, re-wired so that two modules drive each channel (making it a normal stereo chip amp but with more current delivery).
gitarretyp
« Reply #4 on: 22 Jul 2009, 05:13 am »
Bump.
gitarretyp
« Reply #5 on: 2 Aug 2009, 06:03 pm »
Bump.
