0 Members and 1 Guest are viewing this topic. Read 18626 times.
Which raal?
Rick, would the 70-20XR work as the T in an MTM with dual 7-inch Revelators, say in a ported floorstander, or would a different Raal model work better in that application?
Just a guess, but if you wanted dual 7" revelators in a floor standing system, why not think about something like the TRT with the 70-20 as the tweeter? I know I did, it's just that my budget this time could only afford 1 revelator per speaker and not 2.Rick,I know you usually don't say a lot about the sound of your speakers, except to say that they all sound good , but can you share any impressions you might have about the difference in sound between the Prestigio and the Scan Speak Illuminator MTM in the photo above? Regards,ChuckCue Tom Petty, "The waiting is the hardest part". (referring to the Raalevelator of the original post)
Welcome back Rick.General question, what's the advantage of MTM? To control vertical dispersion? With a ribbon tweeter having god vertical control, is it still beneficial? Increased sensitivity maybe?ThanksRich
Will you still have those Thursday of next week? I'll be in the area and would love to come by and give them a listen if possible.
Have any of the listening tests taken place yet?
Any luck getting a good listen in?
