0 Members and 1 Guest are viewing this topic. Read 1717 times.
That's just what I'm looking for! Thanks!Are you using a PC or an Apple? I'm wondering if their would be any connectivity issues.Next problem. . .I'm trying to figure out how to convert WAV files to Apple Lossless. I have the compenent (in the right folder) for Foobar that is supposed to work, but I don't see the option when I try to convert. Ideas on that one?
Quote from: pjchappy on 10 Jun 2009, 01:39 amThat's just what I'm looking for! Thanks!Are you using a PC or an Apple? I'm wondering if their would be any connectivity issues.Next problem. . .I'm trying to figure out how to convert WAV files to Apple Lossless. I have the compenent (in the right folder) for Foobar that is supposed to work, but I don't see the option when I try to convert. Ideas on that one?I am on an apple. haven't really seen any issues for the Remote app with Windows--but honestly haven't been looking. A quick google should uncover issues. Within iTunes itself you can easily convert an album from WAV format to Apple Lossless. Once the WAVs are loaded in the iTunes library, you choose Apple Lossless as you importing encoding type in iTunes Preferences. Then from the Music library view (normal player) highlight select all the songs of an album and choose Advanced > Convert to Apple Lossless (or other encoder). Easy. And fairly quick.There may be some third party batch processor out there for Windows, but Im unaware.
