0 Members and 1 Guest are viewing this topic. Read 5803 times.
I hope nobody is too uncomfortable after sitting on the edge of those listening chairs waiting for me to respond but I have had the Herbie Big Fat Dots (BFDs) in place on my VR5SE for the last five days and swapped them out to listen again with the original feet on the upper modules. Not sure why but in my room and with my system these two coupling approaches really do result in different sounds to my ears. The BFDs are small and look totally inconsequential, not at all as their name suggests, but they change the sonic picture of the Vons, resulting in a noticeably warmer tone with a slightly deeper soundstage which may or may not be to your taste. Certainly the Vons don't look as cool with these in as they do with the original footers which are taller but sonically, I like the results.I was unconvinced at first that this was an improvement rather than a difference but as I kept listening over the last week I found the BFD combo also revealing details in the mids that were less apparent before. I thought at first this was at the cost of upper treble air but over the last few days I've started to appreciate their impact a little more. Certainly fuller bass articulation but also a fuller mid-range, with slightly more body to most instruments and a clearer articulation of transients. Sax in particular seems more palpable, as does piano, and there seems to be a little greater separation of instrumental lines on some recordings. This is good but I still feel I might be giving up some of the extension at the upper end, such as on cymbal crashes which seem a little more truncated with the BFDs. Going back to the original footers, I think the reproduction of cymbals, for example, seems lighter and airier with the originals but more like a stick or a brush actually connecting with metal on the BFDs, although a little foreshortened perhaps in the resulting decay. This might be a trade off that can be compensated for with rear tweeter adjustment or with placement, I've tried to keep it straightforward here for a quick reaction. In brief, for $80 and full-return privileges for 90 days, these are worth trying if you want to eke out a few adjustments to your VSAs and have the patience to play. As with any tweak, YMMV but once again I am reminded of how any change in my system seems to be heard through the Vons.I'm intrigued enough by the results (even if I can't explain them) to keep the BFDs here and have contacted Herbie's Labs about doing a review of a full system-set of products (speaker decouplers, spike footers, component isolation feet etc.) for a future edition of A$$Audio. I will say, dealing with Herbie is very pleasant and he provides responses and deliveries in a prompt fashion. I 'warned' him I was doing this check for the VSA circle so he probably won't be surprised to hear from any of you.
