Wireless Headphones
0 Members and 1 Guest are viewing this topic. Read 2837 times.
Mr Content
Wireless Headphones
« on: 29 May 2009, 10:32 pm »
It would be impractible to have a set of cabled  phones for me, so is there any good quality wireless phones out there?
Mr C aa
ecramer
Re: Wireless Headphones
« Reply #1 on: 30 May 2009, 02:14 am »
I've never personally tried a set but would be interested in fidding out them.
ED
Mr Content
« Reply #2 on: 30 May 2009, 02:30 am »
We have a set for the PC, and when you play a CD, its not half bad, but I don't  have anything to compare it too. I would have to get a 6mm to 3.5mm adapter to try it, maybe thats where I should start. :D
Mr C aa
BradJudy
« Reply #3 on: 30 May 2009, 11:50 am »
I bought a pair of Sennheiser RS-120's for my mother.  I tried them out and they seemed pretty decent, but I didn't do any serious listening with them.
ecramer
« Reply #4 on: 30 May 2009, 01:00 pm »
I threw a shout out over at Head-Fi to see if they know anything about wireless headphone
ED
Mr Content
« Reply #5 on: 30 May 2009, 02:08 pm »
ED
Na ED,you an't going to get me to go somewhere else about this.............hehehe
Thanks, I will have a look too
Mr C aa
ecramer
« Reply #6 on: 30 May 2009, 04:05 pm »
Best wireless headphones - CNET Reviews
I just wanted to check with the people who are realy into headphones for there take on the matter. I wouldn't think about sending you somewhere else
ED
Mr Content
« Reply #7 on: 31 May 2009, 03:13 am »
 Looks like I will be trying  some Pioneer SE-DIR800C head phones, just have to find a shop that is nearby that stocks them. thank for the on site help aa
Mr C
analognut
« Reply #8 on: 4 Aug 2009, 06:57 pm »
I have been using Amphony Model 2500 5.8GHz digital wireless headphones  for about 7 years. The sound is absolutely GREAT. I literally use them every single day, often for extended periods of hours and they work as well now as they did when I bought them.
http://www.amphony.com/products/h2500.htm
The base has optical & co-axial digital inputs, as well as adjustable analog inputs. There is even a built-in battery charger for NiMh batteries on the top of the base, and a high-speed data output so you can connect range-boosters.
Oh, did I mention that I absolutely love this outfit?   :)
binarylinguist
« Reply #9 on: 4 Aug 2009, 09:04 pm »
I used to own the Sennheiser RS-140s and I would not recommend them for serious listening.  For casual TV watching and maybe some music while doing dishes or working out?  Maybe.  Reception can be spotty as you move away from the base.
I tried to use them for movie watching and music listening late at night.  The sound was a bit thin but the biggest issue was that any sort of bass threw them for a loop and resulted in an earful of hiss and static.  They don't handle low frequencies.
My 2 cents...
analognut
« Reply #10 on: 6 Aug 2009, 04:07 pm »
I totally agree with Caliope Home Audio's post (above). I used to have some wireless Sennheisers, can't remember which model.
Hey, I got 'em because when you see the Sennheiser name you think you're getting something worthwhile, right?
Those things were the biggest pile of junk! The sound and performance was so lousy I ended up just tossing them in a garbage can!   :x
